Manual Brake Pushrod issue
Discussion in 'Technical' started by Phyphor1, Mar 18, 2016.
  1. Phyphor1
    Phyphor1 Member
    1972 Mercury Comet
    Just to update you guys, I got an adjustable SSBC brake pushrod (Part #A1726) and will try it out over the weekend. I'll let you all know how it goes.
    Crazy Larry likes this.
  2. 73curtis
    73curtis Member
    ohio
    I couldn't get the old rod out of my master cylinder without removing the master and puting it in a vise , then used vice grips on the rod and hit it out with a hammer , then bench bleed , then put mc back on and bleed complete system , I also used locktite (blue) on rod jam nut , didn't want it to com loose and fall off . I thought it would be a quick job , it would have if I could have gotten the rod out while it was in the car , maybe you will have better luck .
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Yeah, you cannot remove the rod with the M/C installed on the car unless the retainer clip is broken (and hopefully it's not, 'cuz that would be dangerous). It's pretty easy to remove and reinstall though. Having the right length of push-rod will completely solve the problem, so it's totally worth the trouble. Make sure you install a new retainer clip with the new push-rod.
    Phyphor1 likes this.
  4. Rasit
    Rasit Member
    SE Pennsylvania
    I popped the original rod out of the old MC and installed it in the new one.
  5. 73curtis
    73curtis Member
    ohio
    Did it have the steel clip on the end?
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That's what I did on mine.
  7. Rasit
    Rasit Member
    SE Pennsylvania
    Yes, they both had the steel clip. I used the new steel clip on the old rod and installed it in the new MC. By using the original rod, pedal height never changed.
  8. Phyphor1
    Phyphor1 Member
    1972 Mercury Comet
    The new rod has what appears to be a clip on the end, about 1/4 inch from the round point. Is this the retainer clip? I want to be absolutely sure (I plan to tackle this first thing in the morning, but I'd prefer to do it right. )
    I know I'll have to pull the master (I'd have to do so in any case, since the spacer idea would require that, too,) so that's no big deal.
  9. 73curtis
    73curtis Member
    ohio
    Yes that's the clip , once you pop it in you can't get it back out without breaking the clip, compare the original rod to the adjustable one and shorten it , test fit to see if pedal is where you want it if not keep adjusting , then once it's good make sure to lock tite and tighten jam nut . Should work out good.
  10. 73curtis
    73curtis Member
    ohio
    soak all bleeder screws down with pbblaster , may need to heat them up if there frozen , I would soak them down first then start on changing the rod.
  11. 73curtis
    73curtis Member
    ohio
    Just take your time , don't be in a hurry , that's when things usually go wrong ( for me at least )
  12. Rasit
    Rasit Member
    SE Pennsylvania
    Popping the original rod out is sometimes a bitch.
    You will want to fast forward to 8:53 on this video....
    This video shows a hydromax MC but the principal is the same.
    Tannersg1 likes this.
  13. Tannersg1
    Tannersg1 Member
    Classified
    Thanks for the video!
  14. 73curtis
    73curtis Member
    ohio
    How did it go?
  15. dgg54u
    dgg54u Member
    New Orleans area
    1972 Maverick Grabber
    another (and cheaper) route would be to buy the old drum/drum master cylinder and use that rod... Summit wants $45.
    I bought a remanufactured m/c at O'Reillys for $30 that came with the correct rod!
