Manual trans floor hump
Discussion in 'General Maverick/Comet' started by Bum's_Steer, Oct 8, 2014.
  1. Bum's_Steer
    Bum's_Steer Member
    Arkansas
    Are Maverick floor humps for manual transmissions different from the floor shift automatic hump.....if they are, were they unique to the Maverick, or did they share a common manual trans hump with other Fords, like the Falcon or Mustang?
    I know standard floor shifts are pretty rare on Mavericks, most being three-on-the-tree, like mine, but I'm putting a Toploader 4-speed in it, and want a nice factory looking floor hump as opposed to the old just-cut-a-hole-in-trans-tunnel-and-screw-a-Hurst-shifter-boot-to-shape.
    and, to add to the confusion, my car's a 69.5.....which I've heard came with a narrower trans tunnel than the 70-ups
  2. Mavman72
    The tunnel is the same for stick or auto...Floor shift automatics had a bolt on floor hump to mount the shifter...Stick does not.Just cut a hole and your good to go.
  3. Craig Selvey
    I seem to recall that none of the 1969 1/2's were a floor shift....is that correct?
  4. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    I don't think the floor shift was available until the V8 was an option, but not 100% sure.
  5. Craig Selvey
    I had a 1971 with a 200-6 and a factory floor shift 3-speed manual.
  6. Maverocket
    Northwest
    My sons 71 is a factory V8 floor shift manual.
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    My dad had a 71 Grabber 200 I6 with a 3 spd floor shift. I had a 72 Grabber with a 200 I6 with a floor shift as well.
  8. Mavman72
    Yes 69.5 had a smaller (Narrower) trans tunnel...Wont matter for what you want to do.
  9. mav1970
    I looked high and low for a 1969.5 floor shift keyless steering column without any luck what-so-ever. A 3 speed manual was offered in 69.5 but even that was shifted on the column
  10. vvr210
    vvr210 Member
    Vista,CA
  11. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    THAT is EXACTLY how I received mine! With the T56 Magnum mated to the Coyote, had to cut the tunnel as this transmission is a bit bulkier than the TL 4.
