Master cylinder question...may convert
Discussion in 'Technical' started by Hairy W Bush, Nov 26, 2017.
  1. mojo
    Maybe there is air in the system! You might try re-bleed!
  2. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    It's possible. I did it alone.
  3. Krazy Comet
    That's interesting, thank you...
  4. Acornridgeman
    Wisconsin
    Did you bench bleed the master? I was in a hurry not too long ago and skipped doing that. Figured it would bleed out fine once in the car. Wrong. I had to disconnect it all, hook up the bleeder return lines, and work out a couple air pockets on the full stroke. Only then did I get a good pedal.
  5. Acornridgeman
    Wisconsin
    :tiphat: .............. I saved that picture now ....... it is a good one!
  6. mojo
    I agree! Bench bleed makes much easier getting air out of system, once cylinder is on the car. Since it's on the car, I wud get some help trying to bleed system w/o pulling MC if possible.
  7. Hairy W Bush
    Hairy W Bush Member
    Georgia
    Mc is bench bled
    Word of advice do not buy that plastic bleeder kit. The lines aren't clear and th fittings are junk
    Acornridgeman likes this.
  8. Hairy W Bush
    Hairy W Bush Member
    Georgia
    How many of you guys use a proportioning valve with just front disc?
  9. 71gold
    I didn't and don't with 4 wheel disc.
    I was told by a drag car builder that if the rear tires are a bigger dia. than the front I wouldn't need one.
  10. Hairy W Bush
    Hairy W Bush Member
    Georgia
    well it's the same diameter; 17". The car is just using the rear brakes very well and hardly the front.
  11. Hairy W Bush
    Hairy W Bush Member
    Georgia
    i'm quoting this because the man never replied to my question. he has 2 SLS70 switches, with one saying 'General 30891' and the other 'General 30811'. What's the difference?
  12. rthomas771
    I found General 30811 crosses over to Standard Motor Production SLS-70 at https://www.sherco-auto.com/general...-switch-rpl-smp-standard-sls-70-usa-made.html ...so does General 30891 at https://www.sherco-auto.com/general...witch-rpl-smp-standard-sls-70-usa-mexico.html crosses over to Standard Motor Production SLS-70. RockAuto shows Standard Motor Production SLS-70 fits a Maverick http://www.rockauto.com/en/catalog/...rical-switch+&+relay,brake+light+switch,10474 . Also the Ford Master Parts Catalog has a Motorcraft SW-881 listed for the Maverick/Comet. Looks to me like the 30881 should be the part number you're look for.
    Hairy W Bush likes this.
  13. Hairy W Bush
    Hairy W Bush Member
    Georgia
    wait, are you sure you don't mean 30811? because 30881 is entirely different.
  14. rthomas771
    What's different? :huh:
  15. Hairy W Bush
    Hairy W Bush Member
    Georgia
    30881 is for a 70 mustang... And I listed 30811 and 30891
