Maverick 5 lug rear
Discussion in 'Parts Interchange' started by Ford Freak, May 14, 2019.
  1. Ford Freak
    Ford Freak IG page the_marvelousmaverick -- follow me !
    United States, CALIFORNIA
    1972 maverick 2dr 200,c4 ,ac -sold. 1972 Mexican Maverick 302 4 spd - parted out , 1970 maverick v8 swap. 63 Galaxie 500 2dr sedan , 1984 VW Rabbit GTI
    So I’ve got a lead on a maverick 5 lug rear
    Two leads actually
    Well I’m looking to install it on my girlfriends newly purchased 66 A code mustang
    I figured I would check around here for any advise before making a purchase ..
    Any tips would be greatly appreciated
  2. Krazy Comet
    I believe the Maverick rear is narrower than Mustang.
    The '66 A code Mustang should already have a 8", five lug rear.
  3. Ford Freak
    It was removed when I bought the car .
    So
    That is why I’m asking for
    Advise
  4. baddad457
    Might want to look for a Granada/Monarch/Versailles rear too. I think they're the same widths. Spring perches are the same.
  5. dyent
    dyent Member
    vancouver bc
    The Mav/Comet rear end is approx. 3/4" narrower (3/8" per side) than the 66 Mustang, as mentioned, same spring perch width, so will bolt in. The only thing you may have to watch out for, axle tube on Mav/Comet is larger than what came originally on the 66 Mustang, so if you still have the original Mustang lower spring plates, you may have to elongate the holes.
    What year is the Maverick rear end you have a lead on? Also, the Mav/Comet lower spring plates are different than on the 66 Mustang, so hopefully you still have them. If not, I do have correct set of lower spring plates for your GF's 66 Mustang........
    David
    Ford Freak likes this.
  6. Ford Freak
    So good news
    Got the rear end it’s out of a 73 Grabber v8 car .
    I do still have the 66 lower spring plates
    They gave us the u bolts as well.
    I also will update with the goodies I got for my 70 Mav as well
  7. Ford Freak
    I did hear that someone said 67 Mustang spring mounts might work
    I’ll see if I can get some pics of the stang an upload them on this page
    I’m
    Still annoyed I missed out on a good deal on a 72 comet gt
    With a 302
    I would have liked that better than the stang haha
