Maverick front disk brakes
Discussion in 'Technical' started by madmavrik, Mar 31, 2017.
  1. madmavrik
    madmavrik New Member
    Florida
    1971 ford maverick
    HomeConversations>
    Edit ConversationMark as UnreadUnstar ConversationLeave Conversation
    1. [​IMG]
      madmavrikNew Member
      0 0 0
      Hi, I have a 71 maverick with 1975 ford 11 inch stock front disk brake system. The rotors are bad and I decided to replace them with a set of 11 inch drilled and slotted rotors but the posting on ebay never specify they are 1 inch thick originally the factory rotors come .88 or 7/8 thick I call the guy and he said the posting is for a mustang 2 .. well the rotors fit great on the spindles but my stock calipers with new pads won't fit but with the old pads fit perfectly. Is this because the rotors are 1 inch instead of .88 or 7/8 thick? I just need to know if there's a thiner set of pads for this rotor the ones I bought are 8811 hp slotted mustang 2 rotors on ebay if any one has any suggestions Please let me know. .
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You have the wrong rotors for that application. Mustang-II rotors are different from Maverick.
  3. Krazy Comet
    I'll guess finding a thinner set of pads that fit you calipers are zero & none...I don't know what the thickness of stock pads would be, probably .350 or so?? Would mean you'd have to find pads that are each are around .340... If you keep the rotors I'd suggest checking with a brake shop to see if they can cut the necessary amount from pads... It's either that or have the new rotors cut to thickness of orig... That could cause the rotor to be under the minimum thickness spec, I believe .060 is usually the max allowable cut..
  4. 71gold
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Is your Maverick a 4-lug? I always thought the Mustang-II was 4-lug.
  6. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Could you just get rotors turned to take some of thickness off?
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That question was already answered. Rotors have a minimum thickness before they are unsafe and illegal. Just get the correct rotors for your car and don't try to cut corners when it comes to brakes.
    76maverick250 and mojo like this.
  8. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    I agree. Sounded like he really wanted to half ass it.
  9. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    This may not help you...but from what you are saying, these appear to be the rotors that are used in a conversion kit, to adapt modern twin piston PBR calipers to the disc brake spindle. You could consider using the PBR calipers and making a bracket like I am...but that's a lot more work.
    These are most commonly used on mustang II's in conjunction with a GM caliper, they use the same bearings as stock maverick rotors, as you have found out.
    On a side note, I must thank you, I've been looking all over for the rotors they use, and it appears by accidentally stumbling on this post, I have. I just wish it wasnt at anothers misfortune
