Maverick motor swap to HEMI 6.8
Discussion in 'New Members Forum' started by TonyCabra, May 10, 2019.
Tags:
  1. TonyCabra
    TonyCabra New Member
    Mexico
    Ford Maverick 73
    This may sound like insanity, but I had the idea to make a motor swap to my Maverick 73, and one of the modern motors I like the most is the HEMI hellcat 6.8, not only fot the visuals, which are awesome btw, but for the power this beast has, a real muscle motor on modern days. The only problem is that I do not have an idea of where do I start, and I don't really know if it gonna works. You guys have any idea of what are the most importat things to considerate?
  2. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Welcome from the Northeast!
    I believe someone is doing a similar build called the "Hellcalf"
  3. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Front suspension swap.
  4. dyent
    dyent Member
    vancouver bc
    As mentioned above, you are going to have to remove the shock towers, install an aftermarket front suspension, either based on Mustang II, TCP, Rod and Custom etc.....may even have to modify the transmission tunnel, definitely alot of planning, work and money.........!
    David
  5. mojo
    First thing to ask, do you have the fabrication, mechanical skills, time and patience to accomplish this lofty goal? If not, consider a less complicated swap.
    71gold, Hotrock and BBMS18 like this.
  6. Craig Selvey
    Like they say: "If you have to ask...."
    Hotrock, BBMS18 and RMiller like this.
  7. 71gold
  8. stumanchu
    stumanchu Stuart
    Portland, OR
    Welcome from Portland, OR.
  9. Garystac
    Garystac Member
    Tampa, Florida
    None (for now)
    Hello! Welcome aboard! From Tampa. :)
