Maverick not starting
Discussion in 'Technical' started by ukmaverick, Feb 14, 2020.
  1. ukmaverick
    ukmaverick Member
    United Kingdom
    1971 Ford Maverick
    My maverick has been in storage over winter, and when I went to start it with a fresh battery it wouldn't crank. No clicks or anything. The battery had 13V and I had lights, so I was thinking that it could be something to do with the starter solenoid. Does anybody know the best way to test the solenoid to see if it's getting the signal from the key or anything else I should look out for? I've bought a multimeter but electrical systems are not my strong point. Any help would be appreciated. Thanks
  2. Krazy Comet
    If it has the solenoid pictured all that's necessary is jump the S terminal to battery connection. Small screwdriver works fine. If engine cranks there is a wiring problem, if not either solenoid or starter is defective. If solenoid clicks(just once) it's probably the starter. If solenoid chatters, battery is probably weak. Ford 4-Terminal Solenoid Wiring.jpg
    baddad457, Hotrock and BBMS18 like this.
  3. tody
    tody Member
    cologne, germany
    if there's not even a click, tap the solenoid lightly with a hammer. sometimes they're stuck.
    baddad457 and 71gold like this.
  4. Acornridgeman
    Wisconsin
    Neutral safety switch?
    Work the gear shifter around a bit and make sure it is fully into park for an automatic or neutral with clutch in for manual. See if that makes a difference.
    baddad457, 71gold and Krazy Comet like this.
  5. ukmaverick
    ukmaverick Member
    United Kingdom
    1971 Ford Maverick
    Thanks for all your suggestions. I decided to just swap the solenoid out and she fired right up (y)
    71gold likes this.
  6. Acornridgeman
    Wisconsin
    Thanks for the update. Glad it was something so simple …………. :cheers:
