Maverick Problems
Discussion in 'General Maverick/Comet' started by Scraperondubz, Jan 27, 2010.
  1. comet416
    comet416 Member
    michigan
    1970 maverick
    if you havent drove it to much i would try to retorque intake bolts, make sure distributer isnt loose and didnt turn, use brake cleaner to check for vacume leaks. (brake cleaner wont leave residue) spray around carb and intake sealing surface.
  2. Scraperondubz
    Scraperondubz Member
    Oakland, California
    MAVERICK
    I have removed the rims it is now on white letter GT Qualufiers
  3. Scraperondubz
    Oakland, California
    MAVERICK
    I will check for leaks today in a few hours.... I usually drive it 2-3 times a week
  4. justin has a 74
    kentucky
    If the egr valve is stuck open, it can cause idle and hard start up, how new is it?
  5. bmcdaniel
    People have been known to accidently pump in diesel fuel instead of gas. :D We won't mention any names...
  6. toybox06
    toybox06 Member
    ks
    1972 maverick 2dr
    You can buy vaccum gauges/tools at your local parts store that can help you diagnose these type of issues. They even come with instructions how to find a vaccume leak. The trick with carb cleaner/starter fluid is that it will only work if its sprayed in a mist around the possible leak (it must be atomized) and be sure not to spray around the air already entering the engine because the rpm will raise and give you a false reading on the issue. My .02 good luck!
  7. Scraperondubz
    Oakland, California
    MAVERICK
    Its not an intake leak, and i also replaced spark plug wires. I think it way be the distributer not sending enough fire to plugs. it has no power and the shaking is minimual
  8. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    How did you decide no intake leak? They may leak from the inside, usually plugs will show oil an may see smoke out exhaust. Also, with engine running an carefully looking down carb, can you see gas flowing down both front barrels?
  9. douggow
    douggow Member
    Spokane Washigton
    1973 Grabber, Red 71 Grabber, Yellow 71 Grabber
    Being in California, you don't happen to have a catalytic converter on the car do you?
  10. justin has a 74
    kentucky
    oh, good thinking, smog pump too?:huh: (im just guessing, dont know anything about smog pumps)
  11. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    have ya checked the coil.......
  12. justin has a 74
    kentucky
    I dont think that would cause rough idle:16suspect could be wrong though.
  13. comrick317
    comrick317 Banned
    Mississauga, Ontario
    1976 Mercury Comet
    Of course it has a smog pump it's a green car.:rofl::rofl2:
  14. bmcdaniel
    It can, especially if the + & - wires are reversed.
  15. power adder
    power adder Member
    toronto
    1972 maverick
    I think Pauls is on the right track with his idea.You stated that when you removed spark plug wires that you had to remove 2 on one side to see a difference.If you this again and find the cyl that is not firing then you should try one of your old spark plugs or swap from another cyl and see if that cyl fires.If its just a plug then ok.If not then try a leak down test and compression test.You may even need to remove the valve covers to see if a rocker arm has come off.Good luck
