Maverick Problems
Discussion in 'General Maverick/Comet' started by Scraperondubz, Jan 27, 2010.
  1. starsky74
    starsky74 Technician
    Hackberry Louisiana
    broke ring? do the leak down test.
  2. Scraperondubz
    Scraperondubz Member
    Oakland, California
    MAVERICK
    how do u do a leak down test??
  3. Scraperondubz
    Oakland, California
    MAVERICK
    a compression test right??
  4. PaulS
    A leak-down test is done by putting air in the cylinder and checking for the amount and leakage area to determine what needs to be repaired. It tells you a whole lot more about the condition of your engine than a compression test.
  5. justin has a 74
    kentucky
    Might be a shot in the dark but is the cam stock??? mabey a worn down lifter or 2? pull valve covers to confirm.
  6. Cometgt_71
    Cometgt_71 Member
    Saskatoon, Saskatchewan, Canada
    71 Comet, 2 72 Comet GT's , 73 Comet GT, 77 Maverick
    A couple things I ran into over the years was:
    1) engine was fine and then....bad idle, no power, stalling; I removed a valve cover and found 2 rocker arms off of their pushrods.
    2) If your carb was removed, it could have been tipped upside down; sometimes they wont function properly after they're put on again if that happened.
    I changed my intake last summer, and carb at the same time, and it would not idle right unless you held the gas on. I had the intake off a couple times (going crazy like you, looking for leaks and such) and finally tried the carb off my truck and it ran perfect.
    But, like others have said, get a vaccum gage and check, it was the best $25 I spent. You can diagnose a lot by how the needle is behaving.
  7. Scraperondubz
    Oakland, California
    MAVERICK
    Ok everyone.... I have some good news and some very bad news
    bad news:
    Cylinder #1 has 40 lbs of compression
    cylinder #2 has 0 lbs of compression
    thus the engine need to be pulled
    good news:
    I have found a wrecked 1985 mustang gt for $500 not to far from me.... It only has 100,xxx miles on it. So i'm going to go take a look and have it towed to my house.
