Maverick valve covers are here!!!
Discussion in 'General Maverick/Comet' started by Grabber5.0, Dec 30, 2003.
  1. don graham
    still three left:D :D :D
  2. GrabberMav71
    GrabberMav71 Member
    Kentucky
    1971 Maverick Grabber
    I have to admit, i just bought a set:D I was kinda iffy about buying one when he said that he didnt know when they were going to be done, but now since they were in stock and ready to go, i just had to get them.
  3. don graham
    ok, who's going to buy the last two sets?:D
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I like 'em but I wish they had the original-style caps like my Ford Motorsport covers, rather than the push-in gromets...
  5. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Are these tall enough to clear stud mount roller rockers? Stock valve covers don't so are these taller than stock?
  6. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Better check!
    Ok guys, these look to be the same as the ford motorsports/Cobra valve covers that summit and jegs sells.
    If that is the case you will need to check for clearence, roller rockers with a high lift cam will more then likely hit the covers and scar the inside of the covers and the top of the rockers. This is without question true if you are using 1.70 rockers and I cam larger then .550 in lift.
    You may need to double gasket them or use spacer's to get enough height to keep them from hitting. Of course if you are using standard rockers and cam you won't have any problems.
    To Check for clearence I used blue grease on my the top of my rockers and when I no longer saw any on the inside of my covers I knew I had the problem fixed.
    Good luck!
    Terry Gates
    AKA Bossmav
  7. Grabber351
    Grabber351 Quick
    NH
    1973, Maverick Grabber
    :eek: I just ordered the last set on ebay.
  8. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Good thing they didn't say 302 anywhere on them, huh George? :D
  9. Grabber351
    Grabber351 Quick
    NH
  10. don graham
    the article in the last shorthorns says that they are tall enough to fit most roller rocker applications.
  11. bossmav
    Harrisonburg, Va
    better to be safe then sorry
    That's why he can only say "fits most roller rocker applications"
    because they won't fit all if they are the same as the FMS covers!
    Please don't take me wrong, I'm not saying that there is anything wrong with these covers but at the price of roller rockers and these valve covers I sure wouldn't want anything to happen to either one.
    Terry Gates
    AKA Bossmav
  12. 71gold
    being they are one (two) of a kind, if you can get a set, then there might be a motor down the road for you that will not be a roller. i'm sure we have stuff laying around that is mav. stuff and that is the reason we have it,not because it fits a roller motor. when i ordered mine, my mavs. were both 6cyls. jmo....frank...:bananaman :bananaman
  13. jeremy
    jeremy I build t5's
    Corona, Ca
    Thank you for doing that, as I just fell in love with them, and didn't really want to spend $200 on a cosmetic item, now I can't!!!
    Something I'll likely regret not buying though in the future.
