Maverick vs. Mustang rear shackles..
Discussion in 'Technical' started by Dave B, Mar 31, 2010.
  1. Dave B
    Has anyone compared the difference? They are not the same, but I wonder if it's just the bushing size? or the bolt size?
  2. Mavaholic
  3. yellow75
    Tillamook Oregon
    :) Franks answers must be rubbing off on you :biglaugh:
  4. Acornridgeman
    Wisconsin
    I have compared them and it is pretty much just the bushing. But the Mustang ones I had did have a very slightly fatter bolt which made sliding on the Maverick bushing a little tougher, but they went on.
  5. Mavaholic
  6. Acornridgeman
    Wisconsin
    Yes, that looks right at 9/16th for the Mustang and 1/2" on the Maverick bushing. I know I had to really work to get the Maverick bushing onto the larger Mustang bolt but it did go on. Everything then bolted up fine to my new leaf springs.
  7. Dave B
    Hmmm. I even responded to that other post from 2007...
    Thanks for the info!! Solved my problem, pretty quick, back to the drawing board...
  8. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Old timers sneaking up on ya, Dave?:biglaugh:
  9. Dave B
    I swapped my Maverick ones out yesterday, for some slightly longer Mustang shackles. Like Eric was saying, I had to push the bushings on, but a little grease made it easy.
    I found my car had settled a little lower than I wanted, so these shackle raised the car 1", way less work than pulling the leafs, and having them re arched :D
