Max Perfomance!! 351 cleveland
Discussion in 'Technical' started by davemave, Jan 5, 2007.
  1. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Yeah, alot of guys here have 351Ws.
    They actually don't fit as well as the C!
    The taller deck and exhaust ports competing with the shock towers make for some drawbacks to the W.
    One big one being only small tube headers will fit.
  2. patsan152
    patsan152 New Member
    maverick with 351C
    hello guys,i just bought a 72 maverick without engine,and i have a stock 351 cleveland,will the cleveland fit in the maverick without doing modifications??
  3. davemave
    davemave Member
    Guadalajara, Jalisco,Mexico
    It is a maverick 73 rebuilding it and powering up
    :( you need to do some mods to your shock towers, i have a 302 in my mav. and headers are REALLY close to the shock towers, actually, theres a company that makes a piece you can install at your car for the shock towers spacing problem, here is the link:
    www.rrs-online.com
    check it out it has many other cool parts for mavs
  4. ratio411
    ratio411 Member
    Pensacola
    That is the reason a Cleveland fits better than a Windsor.
    On a 302 and 351w, the exhaust exits the engine parallel with the ground. The pipes aim directly at the towers.
    On a 351c, the exhaust points down, so the pipes don't compete with the towers for space.
    You can squeeze 1.75" header tubes on a 302/351w and call them "big". However, they are actually small tubes compared to small blocks by other manufacturers. The 351c in a Maverick can use 'real world' big tube headers with 1.875" or 2" tubes if you so choose, like a comparable small block GM or Mopar.
  5. maverickdvm
    maverickdvm Member
    Michigan
    Everyone always is wanting to try to cram headers in there too. You can run mid 12 second 1/4 mile times all day long with a stock 351C with manifolds and full exhaust. Even then, you don't have to notch the shock towers, but it does make your life easier.
  6. 69shelbmet
    69shelbmet Member
    USA.
    77 Comet.
    Hey, hows it goin with the cleveland setup ? Are you still going to do it?
