Mechanical fuel pump
Discussion in 'Technical' started by fullcm, Jul 13, 2017.
Tags:
  1. fullcm
    fullcm Doug
    Michigan
    74 maverick
    I noticed that my machanical fuel pump is leaking gas on my 250 cid. I clamped off the fuel line for tonight until I can get a new one in the morning. Looks pretty simple, just a hose, compression fitting and two bolts.
    Is it really that easy? any special tips I should know?
    Thank you.
  2. 71Mavrk
    71Mavrk Member
    Nevada
    Yep. Did one in mom's Fairmont and it took about 15 minutes.
    Micah
  3. fullcm
    fullcm Doug
    Michigan
    74 maverick
    Thats good, thanks and hey I like your grabber!
    Is it tricky getting the lever arm in the right position? above or below the cam?
  4. 71Mavrk
    71Mavrk Member
    Nevada
    Thanks.
    For me, the pump went straight in without the slightest problem.
    If your pump has leaked into the pan. You should change the oil. Give the dipstick a sniff for fuel.
    Micah
  5. fullcm
    fullcm Doug
    Michigan
    74 maverick
    got it installed, was very easy. I ordered a used Chiltons manual for stuff like this but it has not come in yet. Thanks for the advice everyone. And I did change the oil as well as a precaution.
    71Mavrk likes this.
