Michigan Mick's 71 Comet Project
Discussion in 'Maverick/Comet Projects' started by mstolarc, Sep 6, 2010.
  1. mstolarc
    mstolarc Member
    Livonia, MI
    1971 Comet GT (clone)
    Engine Disassembly
    It is now August 2009 and time to take apart the engine. My brother has tortured this poor engine. He sent the trans out to his "trans guy" to get it rebuilt.
    The bare block
    There was a broken cam bearing, here's the crank and worn out cam
    Timing chain gear was really worn and cracked. As i said before we knew the engine didn't have long!
    My brother built a makeshift tent to use his portable sand blaster to clean out the engine compartment.
    Blasted engine compartment
    Block is back from being freshly machined. Bored .030 over and decked for better compression.
  2. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    nice job mick your getting there.you ever get over to milan dragway?
  3. mstolarc
    mstolarc Member
    Livonia, MI
    My brother takes his 68 Mustang there quite a lot. Believe it or not I have never been there! When the car is done I am going to give my brother the honor of seeing what it can do and then I think I will give it a try. He tells me I will really enjoy it. He says he does his racing at the strip and not on the road.
  4. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    yeah thats what i do and i plan on taking my mav up there in the spring.right now im runnig it in norwalk ohio.and your brothers right to many things can happen on the road at least at the track they have safty crews.
  5. mstolarc
    mstolarc Member
    Livonia, MI
    Engine Rebuild Time
    Alright here we go. I am by no means a gear head and mean no offense to those of you that are. I thank my lucky stars that my bother has this talent!!
    I am about to assemble my first engine. I don't really have a clue what I am doing but I can follow instructions. My patient brother took me through this process every step of the way.
    New freeze plugs and cam rings installed.
    Installing the pistons
    Here's the roller cam. Comp roller cam. 0.512 total lift, 221 degrees duration at 0.050" lift, 110 LSA. Don't know what any of that meant but my brother told me some of you might ask questions about it so there are the specs.
    Happy Mick with Happy Engine (I hope)
  6. mstolarc
    mstolarc Member
    Livonia, MI
  7. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    wow mick that really looks nice and im a novice engine builder too.but i got my car running 13.27@102.36mph at summit motorsports park last night.
    john
    P.S. i from just east of toledo in fremont ohio and i bleed ford blue.
  8. mstolarc
    mstolarc Member
    Livonia, MI
    Interior Disassemble and Front End Painting
    We're up to the fall of 2009. Time to take the interior apart and paint the front end
    088_interior_disassemble_9-09.jpg [​IMG]
    Test fitting the power brakes. We added power brakes to the car with Granada front disc brakes.
    Painting the front end.
  9. mstolarc
    mstolarc Member
    Livonia, MI
    Engine Painting
    Alright we finally caught up to this year. These pictures are from April of this year. My brother painted the engine the same color as the exterior of the car PPG Medium Green Polyurethane.
  10. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    great build pictures, looks awesome.
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Looking good.....
  12. mavgrab302
    Looks Great........
  13. mstolarc
    mstolarc Member
    Livonia, MI
    Can't Upload
    I've been trying to for two days to add some more pictures to this thread but I can't seem to get it to work the way I did before. So I'm just posting a reply without pictures to see if this maybe miraculously clears up the thread so I can post again.
    I'm trying to add some pictures of the rear end work and under body clean-up. So stay tuned to see if I can clear up this technical glitch.
    :huh:
  14. mstolarc
    mstolarc Member
    Livonia, MI
    Rear End Work
    Going to try and go back to inserting the pictures the old way since I can't seem to insert the larger pictures right in the thread.
    Here is the rear end work from April of this year.
    103_rear_end_work_4-10.jpg [/img]
    106_rear_end_housing_4-10.jpg [/img]
  15. mstolarc
    mstolarc Member
    Livonia, MI
    Under Body Clean Up
    Scraping off the old seam sealer
    112_underbody_clean-up_4-10.jpg [/img]
    Cleaning up 40 years of crud
    114_underbody_clean-up_4-10.jpg [/img]
    Extremely solid rust free metal under car. Still has factory paint on it !
    115_underbody_clean-up_4-10.jpg [/img]
    Applied 3M spray on undercoating
    116_underbody_undercoat_4-10.jpg [/img]
