MII upgrade progress (pic Heavy)
Discussion in 'Maverick/Comet Projects' started by BigDog41364, Feb 23, 2015.
  1. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    My son and i started the project while he was home for Christmas. We removed the engine and suspension.
    Then shock tower removal
    then a lot of grinding to prepare the frame rails
    Yesterday i tack welded the cross member in place. Now have to wait for a friend from work who is a master welder to come out an finish welding it for me.
    71gold likes this.
  2. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Looks good! I figured I had 15 hrs in my swap to get it back to "roller" status. That's not counting the steering column mods. Would have been much less had I used my plasma cutter instead of drilling spotwelds...
  3. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    My biggest battle is going to be mother nature, its only going to be in the low teens for the next week. Need it to get a little warmer before i can paint the engine bay. in the mean time ill re wire, re do the break lines, traney lines, and finish rebuilding the motor. My rod and main bearing are shot from the comp cam i chewed a lobe off of last summer.
  4. mojo
    How u figure the cam lobe was chewed up? Hope to hook-up w/ u guys agn this year at NSRA, reservations made and registered for the event. I'm waiting for the spring wx too, got some upgrades on my list also. Looks like u have gud start on getting the M2 setup on its way.
    slopoke likes this.
  5. mav1970
    Very nice job on your new suspension :thumbs2:
  6. mercgt73
    Awesome work! Exactly what I hope to be doing someday. (y)
  7. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I had one lifter that kept coming lose, or so I thought. Ended up getting frustrated so I pulled the intake and the lifter out, about .250 in was missing off the end of the lifter. So pull the heads and the cam and most of the lobe was gone also. It didn't wear off quickly, I had about 1500 miles on the motor rebuild, so I figured if any metal had already went thru the motor. Decided to wait and do the rebuild when I pulled the motor for the MII install.
  8. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    thanks,:)
  9. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Thanks,
