Mini Tubbed!!!
Discussion in 'General Maverick/Comet' started by ModMav71, Oct 28, 2008.
  1. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    lookin' good Travis!!!!!
  2. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    Your mini-tub looks good....lots of work,like the tri-4 bar.
  3. soooulpower
    Mapleton Depot, Pennsylvania
    Ditto for me. I love big fat rear wheels.
  4. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Looks great! I like the use of the stock wheel house/tub. You don't see that too often. (y)
  5. Hangbelly Mafia
    Hangbelly Mafia Member
    N.W. Corner
    Do you know what size tires/wheels you are going with yet?
  6. CaptainComet
    Lookin' Good :thumbs2:
    I am working on the floorboards in mine right now and keep looking back at my tubs, thinking about doing this myself. I have 265/50s right now, but 295s would look better....:thumbs2:
    Did you go in beyond the original frame rail?
    I want to keep the a stock-appearing interior, so I want to see if the tub can come in a bit and still use the rear quarter panels, etc ...
  7. ModMav71
    ModMav71 Member
    Sebring, FL
    This sits pretty much flush with the frame rail. In the rear its sits inward about an inch or so this is due to the stock frame rail turning outward in the rear. I will write a tech article in the next few days, that way no one makes the same mistake I did! This should fit a 295 tire fine with a rolled fender lip. I measured from the frame rail to the outer lip on the quarter and its alittle over 13 inches.
  8. ModMav71
    ModMav71 Member
    Sebring, FL
    18x10 in the rear with a 285-295 tire, 18x8 with a 225 tire in front. I have a few wheels in mind. #1 wheel choice is the Foose Nitrous.
  9. Mavaholic
    You should have started on the drivers side. I have a NOS inside wheel well for that side. :D
  10. soooulpower
    Lucky. I almost said "You have NOS Tubs?". I just woke up.
  11. Hangbelly Mafia
    N.W. Corner
    That should look great, I have a set of Foose Nitrous II that are 20's for my 94 Thunderbird, just waiting to get tires.
  12. AllRoundCarGuy
    AllRoundCarGuy Member
    ND
    1970 Maverick Restoration
    Curious how much room these mini tubs free up. Looking to build a street/strip car and want to keep stock rear interior. At least as stock as possible. I want to put slicks on it when I go to the track and I need some decent size meats to lay down about 600 hp to the ground.
  13. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Mine's mini-tubbed and has the frame rails "pinched" and springs relocated 3" inboard. I've got 325DR's on it and have 1" clearance on the springs and 1" on the fender lips...
    Russ
  14. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    ^ more info please,like how'd ya move the springs inboard and by pinched ya mean ya nocthed the rails and if so how much?
  15. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    I pretty much copied Crite's (early) comet/falcon kit, as they don't offer one for Mav's. The rails were notched 2" and the mini-tubs were built to match the rails. E-Mail me and I'll send you some pix, I'm about out of space here...
    Russ
