Misfire, can't find problem and have tried everything. Please Help
Discussion in 'Technical' started by bburns1000, Apr 11, 2014.
  1. bburns1000
    bburns1000 Member
    Cook Forest, PA
    1975 Maverick
    No, Installed cam per manufacturer instuctions. Piston#1 @ TDC and timing marks lined up perfectly.
  2. baddad457
    "Lunati Street/Strip cam" tells us absolutely nothing. (specs would help) And your admission that you over rev'd it and don't baby it tells me you've damaged something internally. Did you pull the cam back out to inspect it ? Pull the lifters to inspect them ? Backfiring through the carb could be an indication that there's something amiss with one or more exhaust lobes/valves. If an exhaust valve doesn't open, the pressure gets trapped through a few cycles till it escapes through the open intake valve.
    Rasit likes this.
  3. lm14
    lm14 Member
    Iowa
    Check your MSD wiring. There are purple and green wires that don't always stay purple and green and people mix them up. Check those wired between the box and distributor. If they are reversed it will retard the timing.
    SPark
  4. bburns1000
    bburns1000 Member
    Cook Forest, PA
    1975 Maverick
    I finally figured it out. The diaphragm blew out of the pressure regulator. The electric fuel pump was putting close to 100psi of fuel in the carb. Rebuilt the regulator, bought new carb ( the pressure and backfires ruined the old one) degreed the cam and timed it straight up. Runs better than ever now.
    Thanks to everyone for all help
  5. 71gold
    why is there a pump on there that puts out that much pressure?
  6. bburns1000
    bburns1000 Member
    Cook Forest, PA
    1975 Maverick
    Car was not street driven in the past, former drag car.
  7. Bryant
    I'm surprised it didn't shoot fuel out the bowl vents. I would expect it to be able to shoot fuel at least 20 feet up at that pressure!
    baddad457 likes this.
  8. baddad457
    Even on a drag car, a carb doesn't need that kind of pressure in the fuel pump.
