monty carlo bar?
Discussion in 'Technical' started by Pratt, Dec 7, 2019.
  1. Pratt
    Pratt 347 grabber
    salinas ca
    1972 grabber
    does any one have a source for Monty Carlo bars for my 72 grabber?
  2. dyent
    dyent Member
    vancouver bc
    There was a member TOPORANGER who used to fabricate Monte Carlo and Export Brace bars for our Mav/Comets, but I do not know if he is still making them or not. He has not been on the site for a couple of years, but you can try and PM (start conversation) him, as he would get a direct email notification without having to be on this site........
    Others, including myself, have used ones for 65-70 Mustangs and modified them to fit, good luck!
    David
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    define "modified"
  4. dyent
    dyent Member
    vancouver bc
    Here are a couple of pictures of my "modified" bar, I can not remember, but I think I had to lengthened, been over 30 years since I did this! I used the "curved" bar to clear the distributor on our 302's, pretty simple mod and then you have to drill a few holes to install the bar.
    David
    gator25 and mojo like this.
  5. 2MCgts
    2MCgts Member
    Loganville, GA
    75 Comet
    Fabricate your own. Draw , figure out what you want it to look like n what you want it to help. Any good local speed shop should be able to weld it for ya. Had them done for both of my car's fairly inexpensive. My car's are rack n pinion so a little easier to Fab up. 20170813_194108.jpg 20170813_194108.jpg IMG_20181203_174502.jpg
  6. TeeEl
    TeeEl Senior Member
    Colorado
    0330171523.jpg I had mine made by that member many years ago. It was shaped to clear the factory A/C compressor. Wish he still made 'em because I'd like to have one made of a stronger tubing...
    gator25, rickyracer and mojo like this.
  7. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    I really like what you've done here. Diagonally bracing the front fenders to the core support can add a lot of strength to a front end. While they're obviously built entirely differently, front fender to core support bars are important to front end stiffness of Camaros and Firebirds. Same is true of the inner fenders, even though they bolt on in those cars.
  8. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    This is a year or more later. Any source for that Monte Carlo bar yet or will I have to show some pictures to my local welder?
  9. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Unless the fender apron spacing coincides with the width of one of the early Mustangs I think you're on your own, but it's very basic fabrication.
  10. TeeEl
    TeeEl Senior Member
    Colorado
    The Mustang width is slightly more narrow. The reason you can squeeze a bigger engine into a Mustang is because the spring towers don't come in as far as the Maverick...
  11. bmcdaniel
  12. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    That looks good and sturdy. I like it.
  13. mavgrabber01
    mavgrabber01 Member
    Washington
    1972 grabber
    Any details on this? Custom made? If so, care to provide dimensions?
  14. x72COMETx
    x72COMETx Member
    Vallejo CA
    Jaybee and dyent like this.
  15. dyent
    dyent Member
    vancouver bc
    jasonwthompson likes this.
