monty carlo bar?
Discussion in 'Technical' started by Pratt, Dec 7, 2019.
  1. TeeEl
    TeeEl Senior Member
    Colorado
    If the car has A/C, a straight bar won't clear the compressor...
  2. BruceS
    BruceS Member
    Texas
    1973 Comet
    The one McDaniel posted isn't near the compressor.
  3. dyent
    dyent Member
    vancouver bc
    His is an Export Brace and does not have a Monte Carlo Bar, which is tied in front of the shock towers, like member Shorty (Bruce) in post #29
    David
    TeeEl likes this.
  4. bmcdaniel
    When I made my bar the idea was to try and incorporate both types of bars into one solid, welded piece with only straight bars. The cross piece effectively makes the long bars shorter and stronger, and they're attached to the shock towers. They won't allow movement in any direction.
    (I can't for the life of me figure out why they make bars with spherical rod ends that are only solid parallel to the bar and rotate in every other direction.)
    The suspension loads and engine weight are carried by the shock towers into (mostly) the lower frame rails and finally into the cowl. That was the reason for the belly bar. Most of the Monte Carlo bars I see just screw into the sheet metal in front of the shock tower. Obviously they work better than no bar but...
  5. BruceS
    BruceS Member
    Texas
    1973 Comet
    Well if I chose one it would be the export brace.
  6. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Looks and works great, only issue is getting at that rear carb bowl. Moved back just a hair would make it perfect.
  7. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    They're easy to install, because chassis that have flexed over the decades can still adjust the assembly so it attaches in all the right places...which would lock the car into an out of shape condition if they had enough stiffness to make much of a difference.
  8. mavmo
    mavmo Member
    Vancouver wa.
    73 maverick
  9. mavmo
    mavmo Member
    Vancouver wa.
    73 maverick
    Deltabay mustang and maverick parts online.
  10. dyent
    dyent Member
    vancouver bc
    Yes, they have nice Export Brace (shock towers to firewall), similar design to what Shelby used in his 65-70 Mustangs........but like everything else, I believe they are on back order.........
    David
