More PCV questions
Discussion in 'Technical' started by scooper77515, Oct 15, 2006.
  1. stephen
    stephen jet mechanic
    Albuquerque, NM
    69.5 Maverick
    I see the benefit of the PCV system, but when I had mine hooked up like it is suppose to be I had smoke coming out the mufflers. The valve covers are baffled, I have a breather on the the drivers side and the valve on the other with a hose going to the back of the carb. When I removed the hose off the carb and plugged the carb the smoke stopped. This was taken during the cam break in run.
  2. PaulS
    Stephen,
    That kind of smoke is usually from a system with a bad PCV valve, one that is not sealing!
    Paul
  3. mavman
    mavman Member
    Arkansas
    A sign of a good racer! It's called bending the rules. He who bends the rules usually wins until they change the rules...then we have to bend them some more!
