Motor Oil
Discussion in 'Technical' started by pintoches, Oct 8, 2004.
what filter is the best
  1. K&N
    7 vote(s)
    13.5%
  2. wix
    10 vote(s)
    19.2%
  3. fram
    14 vote(s)
    26.9%
  4. ACDELCO
    0 vote(s)
    0.0%
  5. Motorcraft
    21 vote(s)
    40.4%
  1. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    I have heard the same things over and over about Fram. Not sure how cunsumer reports tested theirs, but their results are contrary to every other report out there.
    Most reports I have seen rate Wix really highly. I buy Motorcraft filters.
  2. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    oiling
    Fram filters have gone down hill in the last 5 yrs due to corp changes. Wix has always been good as is NAPA/Motorcraft/puralotor, all the same manufacturer. KN filters are good also. Military soecs require the oil to be tested and replaced in the tests say so, and change the filters every so many hours. The aircraft industry uses Syn oil and has for years. As far back as WWII, in both jet and piston engines. My 98 Explorer manual says 5K on extreme conditions and up to 15K on normal conditions with filter changes every 5K. Issue here is money. Oil comp want you to change that oil and the recycling comp want you to also. You pay them to take it and they sell it to someone else. They make money twice. Most of the old oil from 40-50+ years ago was from soybeans and the leaded fuel/piston rings contaminated pretty quick. So you had to change the oil every 3-5K miles.
  3. pintoches
    pintoches Member
    Reeds Spring near Branson Mo
    76 Marerick, 77 Ford F-250, 78 Ford Cougar
    Do any other filter have some thing like the shure grip?
  4. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    A pair of gloves with rubber/gripper fingers does the same thing as the grip piece on the junky Fram filter.
  5. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    If you want the sure grip on any filter, clean the new filter off, take a can of undercoating and spray as much sure-grip as needed! I don't really care about the sure grip, though. Just me. Preston
  6. riporter
    riporter Member
    Charleston S.C.
    20 people will give 20 different opinions on this. You already know what has worked well for you (Castrol)
    Personally I use Royal Purple and a Napa Gold filter because I know how well it works.
  7. stmanser
    Davenport, Iowa
    I have used FRAM in every vehicle i have ever owned, and i have never been let down
  8. 71gold
    Simon, ...little late on your reply...10/15/04 :tiphat:
  9. mean_maverick
    isnt this always the case....lol
  10. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Well,,,, he only wanted, in a timely fashion, give it much thought!
  11. scooper77515
    Since this was brought back up, what is the consensus on the synthetics being used in newer motors only? I thought about switching to Purple after I break my new motor in (break IN, not BREAK...) and since it is basically an HO motor, thought it might work well in it.
  12. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Start a new thread and let this die.
  13. scooper77515
    Not worth my time to start a new thread. As cheap as I am, I will probably just keep buying the trusty ole Castrol 10w30...
    You know me...:huh:
    I just figured that since it was brought back up I would toss that in there.
  14. Jamie Miles
    Alto, GA
    I've had a few
    My grandpa and uncle run Mobile 1 in their trucks, change the filter every 5,000 (Motorcraft) and and oil every 15,000. Grandpa bought his '05 F150 XLT new (5.4 V8/auto) and it now has 90,000 miles with 7 oil changes to date. Uncle bought his 2000 F150 Sport (4.2 V6/5 speed) used in 2001 with only 6,000 miles and it now has around 350,000. Both trucks run excellent, though my uncle said he his getting worried about the original timing chain and clutch in his.
    Everyone in my family has always run Castrol in their older vehicles. I run 10w30 in the '72 (FL1A Motorcraft filter) and change the oil and filter every 4 or 5,000. Back when I first started driving my '74 Grabber, the 250 in it was absolutely nasty inside. Under the valve cover it was covered in sludge. Within 5,000 miles of driving (changed the oil 3 times in those first 5,000 miles), the engine was near spotless inside. I am a strong believer of Castrol in older cars.
  15. Mavman72
    Dirty oil is dirty oil,3000 mi for dino sauce before additives go by by and contaminants start doing damage.Most synthetics 5000 mi then by by.I have allways used fram filters and have never had an oil related engine problem.
