motor shaking like crazy... process of elimination
Discussion in 'Technical' started by indabebe, Aug 31, 2011.
  1. baddad457
    It's a Vacuum leak. :Handshake Or you've got a really nasty cam in there.:thumbs2: Sound would go a long way in that video to confirm this.
  2. indabebe
    indabebe Member
    86 nissan 720
    I don't have a transmission vacuum line hooked up. Does that matter?
  3. baddad457
    Yea. It does matter, is the port on the intake it goes to open ?
  4. indabebe
    indabebe Member
    86 nissan 720
    No, it's all capped
  5. baddad457
    I've got sound now on that video. You've got a vacuum leak. Spray all around the intake with carb cleaner, when it gets to the leak, you'll hear a change in idle.
  6. indabebe
    indabebe Member
    86 nissan 720
    Nice, I'll check it tomorrow. What do I do if there's a leak? What will I seal it with?
  7. baddad457
    Depends on what the leak is.
  8. 71gold
    first see if there are any, then we will guide you to the correct repair...
    if you have any...caps...on any vac ports, check them to see if any are split...(y)
  9. indabebe
    indabebe Member
    86 nissan 720
    i dont want to sell it,i just got frustraded. but, ill go thru this slowly. im about to recheck everything in a bit.
  10. Moneymaker 1
    Panama City Florida
    Did I see the choke not opening up?
  11. blugene
    I hear a vacuum leak and too high on the idle.. Might also be hearing a missfire but that could be the cam. How's the response when you snap the throttle?
  12. indabebe
    indabebe Member
    86 nissan 720
    sounds okay, but it shoots up gas to the hood. i tried to drive it out the yard today and it when i stomp on the gas, it bogs a bit. it drove okay when i was pressing the gas a little bit, but when i press it a little bit more, it died and did not want to start up again.
  13. blugene
    The idle needs to be the first focus. If you can't get it down then start looking for the reason why.. like a vacuum leak. You don't want a real lean condition. Once the idle is stable and low then move to response.
    All that I keep reading and feeling is there is a leak. Could be the carb itself. Whenever I start trying to adjust for lower idle that's when I begin to see where problems are like mixture screws out too far or carb plate not quite sealed due to gasket.. How about vacuum? What's the reading?
    I am not familure with the Edelbrock carb so not sure how to go about setting it.
