motor swap ideas?
Discussion in 'Technical' started by hyperballsmcgee, Apr 13, 2012.
  1. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    I would not do the upgraded 6 cyl unless it was a 250. for all the money you will spend upgrading a 200 you would be miles ahead with a 302.
  2. 71gold
    what you really...wanna...is more money...:D
  3. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Frank nailed it!!
  4. hyperballsmcgee
    hyperballsmcgee Member
    Murfreesboro, TN
    1974 Maverick 2 door
    thanks for all the input, but I feel like I was misunderstood. my mpg is perfectly fine right now, but I meant on a different motor I wanted good mpg with good amount of horses. but from a little more research I've found it would be best, and unique, to have a bad-a** inline 6. I'm thinking a new intake, 2 barrel carburetor, and headers. sound good?
  5. Jamie Miles
    Alto, GA
    I've had a few
    You can't replace the intake on a "small block" straight 6, it's cast in as part of the head. The header and carb are good starting points, but will cost several hundred bucks unless you can score a good deal on used parts.
  6. 71gold
    upgrading for more power means upgrading the drive train.
    power ain't free...you have to feed them ponies after you buy the parts to make them...:yup:
    after you build that 200 you might have the same power as a...stock 2V 302 for less money...:tiphat:
    as Ward said..."I would not do the upgraded 6 cyl unless it was a 250. for all the money you will spend upgrading a 200 you would be miles ahead with a 302."
    ...JMO...:bouncy:
  7. Craig Selvey
    We told him what he wanted to know. Unfortunately....it is not what he wanted to hear. :D
