Motor swap
Discussion in 'Technical' started by Stefan Lindholm, Jul 18, 2015.
  1. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Rock auto lists the 200 8" axle bearing and 302 axle bearing as the same part # in the catalog. ?
  2. Krazy Comet
    Been discussed a few times here on board, but I don't have first hand experience.... They are listed as different in the '65-'72 Master Parts Catalog... I'm guessing all from '73 up are same(I don't have the later catalog)...
    Mavit likes this.
  3. Stefan Lindholm
    Stefan Lindholm Member
    Finland
    Ford Maverick Grabber 1972
    How mutch wider is a mustang rearaxle. Would i got problems later with the width if change to a mustang rearend. Saw a tread earlier about spacers what made the axle 1" wider on bouth sides, what are you guys thinking about them. Must be the easiest and cheapest way to convert from 4 to 5 lug.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    'Depends on the year of Mustang. All are wider than Maverick/Comet rearends.
  5. 6inarow
    6inarow Member
    71 maverick
    Since you're limited on engines, you should turbo that six. Turbos are plenty over there, and I'm sure you Fins can think of something. I've seen crazy turbo tuning in inline sixes, they can wail!
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Not all inline sixes are created equal. Those old sixes that Mavericks & Comets had are best used as boat anchors.
    A modern six would be a different story.
    Mavit likes this.
  7. rthomas771
    I have to disagree on that. I seen these little sixes, with a little work and money, can spank some 302's.
  8. 6inarow
    6inarow Member
    71 maverick
    I'm currently contemplating a 6cyl swap as well. There are tons of inline 6's that make 2-3 times the power from factory. Bmw is the inline six of my choice, slightly biased, because they are relatively same size and the power is very good for its weight. A 3.5 Bmw engine of the 80's made anywhere from 180-210. The only downfall is they're canted, and maybe won't fit.
    Japanese engines are great as well. the 7mge, or 1jzge, both make great power stock, and are dohc. Carbs can be retrofitted, so it's possible to do without a computer
  9. Krazy Comet
    When Ford introduced the 250 in '69 was stated it would accelerate evenly with a 302 to 50mph...
    Only fresh 250 I've ever driven was a new '72 Stang with three speed, was fairly brisk in 1st & 2nd, had enough torque to easily break the RR tire loose on a quick take off... Would have no doubt been quicker in a Maverick but I dunno if it was available with a stick, in the earlier years only automatics were avail(at least '71)... I know the 250 could be had with a stick by '74 as I owned one but it was getting a bit tired by the time I got it......
  10. rthomas771
    ^^I got all my t5 swap parts from a '73 250 Maverick
    Krazy Comet likes this.
  11. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    For the price of making a 6 go you could bolt in a mild 302 that would be faster! I agree that a 6 can go but the cost is high! I had a friend back in the 1970's that run a Maverick with a 300 ci 6 that run into the 11.00 second range at the drags but it was not a lo cost car!
    Crazy Larry likes this.
  12. 6inarow
    6inarow Member
    71 maverick
    Well where he is located makes things a bit tricky.
  13. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I can't see messing around with the old 200 or 250 from the '70s. Modern 6-cylinder engines are very good performers, and if a V-8 is not attainable, that is what I would recommend.
    Mavit and Rasit like this.
  14. groberts101
    groberts101 Member
    Minneapolis, MN
    The old Ford 2.3's are VERY good engines with TONS of aftermarket support. With todays newest tech and computer controls you could easily turbo one of those well into the 400 horsepower range and still get decent mileage too. Ford sold those things just about everywhere too so there should be no major shortage of donor cars to get er' done.
  15. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    5 lug v8 with disc brakes 250 six is a boat anchor
