Mounting Grabber Hood Scoops
Discussion in 'General Maverick/Comet' started by Mikef, Jun 25, 2022.
  1. Mikef
    Mikef Member
    Inland Empire, Southern California
    1971 Ford Maverick
    I just ordered and installed a new grabber hood. I also order the vents/scoops. I’m sure these scoops must glue down? Is that correct? If it is can someone recommend what I should use to glue them down. Thank you.
  2. Acornridgeman
    Wisconsin
    Scoops are held in with 3 special nuts. I'll dig up a picture for you.
    There is no gasket - just the nuts.
    Here it is - stamped acorn nut with a rubber grommet in it.
  3. Mikef
    Mikef Member
    1971 Ford Maverick
    yeah. There are three little studs to hold it in place but no threads on the studs.
  4. Mikef
    Mikef Member
    1971 Ford Maverick
    I can’t see the pic for some reason.
  5. 71gold
    I also get a red X ...
  6. Acornridgeman
    Wisconsin
    Linky voodoo .......... try this
  7. Acornridgeman
    Wisconsin
    As long as the studs are there that is all that matters. They are not threaded like a screw - the nut bites into the stud and threads itself. Self thread cutting acorn nut.
    71gold likes this.
  8. BruceS
    BruceS Member
    Texas
    1973 Comet
    Or you could thread the studs with a die and install nuts on them. I wouldn't do it but it's a option.
  9. Krazy Comet
    Back in day Ford included attaching hardware with part.
