Moving right along...
Discussion in 'General Maverick/Comet' started by ModMav71, Apr 6, 2007.
  1. AUSSIEBJ
    AUSSIEBJ http://mmb.maverick.to/at
    NEW YORK
    70 Mav old race car project,70 mav 460 ,C6 9" posi 4.11rear SOLD
    The kit is the way to go otherwise you will not be able to roll it around when u r done, and see your handy work completed..set aside a weekend and take lots of mm before starting and check and recheck mm as you go...Give it a shot...its more satisfing knowing u did the work yourself
  2. mav1970
    You can't use any of your stock Maverick steering anymore when you install any of these Mustang II "type" systems. You have to have the Mustang II rack. :)
  3. MikeG747
    MikeG747 Member
    Arkansas
    What would you use if you were to do it again?
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    What he said and why would you not go M2 again?
  5. ModMav71
    ModMav71 Member
    Sebring, FL
    I would probably go with a Corvette based suspension. Better geometery and more brake options.
  6. mojo
    What Vette based suspension wud U use?
  7. ModMav71
    ModMav71 Member
    Sebring, FL
    There's several companies out there making crossmembers and front suspension kits to put the Corvette front suspension under anything from a ford pickup to a camaro. I'd use a C4 or C5 suspension, both are plentiful now.
    On a side note. Nothing new with my Maverick. Been putting some money and time into the Pinto since it's my daily driver...it needed some attention. Will be putting the 2.3 Turbo short block together today. :dancing:
