moving
Discussion in 'General Maverick/Comet' started by fordboy1989, May 29, 2014.
  1. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Really, don't forget to mark the orientation of the connector, it's fairly important to put it on in the same position it was taken off for balance reasons.
    Or so I've been told.
  2. Craig Selvey
    How far are you moving the car?
  3. fordboy1989
    fordboy1989 Member
    indiana
    1973 mercury comet
    from point a to point b[:rofl2:
  4. fordboy1989
    fordboy1989 Member
    indiana
    1973 mercury comet
    i just wanted to thank everyone for being so helpful
  5. Rasit
    Rasit Member
    SE Pennsylvania
    Tie it up with rope, a strap or wire.... or 300 zip ties.
  6. rthomas771
    Remove driveshaft and duct tape a plastic around the tail housing. If your driveshaft falls it would be toast
  7. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    Leaving a manual transmission in neutral would be fine for a cross - town move, but any further can do damage. The main shaft turns with the driveshaft, but gets no oil since the counter shaft is not turning.
  8. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    Make sure you duct tape or electrical tape the ends of your U-Joint so the needle bearings don't fall out....
