Mr.Gasket fuel pump work good for fuel insurance?
Discussion in 'Technical' started by garrettmuir1227, Oct 22, 2014.
  1. garrettmuir1227
    garrettmuir1227 (Almost) Certified to Work on Your Porsche
    Temecula,CA
    1974 Mercury Comet (small bumper Mav converted) 2009 Mustang Bullitt #5834
    hi i got a nitrous kit for the Maverick and one of the parts I'm collecting for the setup is a fuel pump to back up my mechanical pump, since proper fuel flow is important in a nitrous car. So my question is, would a Mr. Gasket fuel pump be adequate for this job? I noticed they are cheap so it's worth a shot at least to see what y'all say about it. Any opinions, facts, tips, would be great. Thank all in advance!
  2. Bryant
    i wouldnt use it. if the fuel pump can not feed enough for the nitrous then you will melt pistons. so a cheap pump can mean a expensive engine failure. ive used a mr gasket pump on a car that had a fuel pressure gauge as a road side fix just to get home and the pressure would start to drop off at about 1/2 throttle.
  3. garrettmuir1227
    Temecula,CA
    Wow okay cool thank you for the info
  4. 71gold
    I see no problem with it ( backing up a mechanical pump). they run them on EFI swaps all the time...:yup:
  5. garrettmuir1227
    Temecula,CA
    Would it be okay you think at least until I get a better? Like Holley or better?
  6. 71gold
    if you are using it as a backup pump....how are you planning to plumb it?
  7. garrettmuir1227
    Temecula,CA
    in line before the mech. pump. not sure if its better close to the tank or the mech. pump...
  8. 71gold
    most E-pumps are mounted close to and below tank.
    what is your thinking to use both?
  9. garrettmuir1227
    Temecula,CA
    basically to make sure i have proper fuel flow into my carburetor. if i go to lean on spray that'll be bad.... so a backup pump is always helpful i think
  10. baddad457
    If you're thinking about the 12S pump, I doubt that's going to feed a NOS unit. Doubt also the mech pump is up for that either. I'm using the 12S to feed my 3 twos (at WOT) , and it's plenty for that, except when the fuel filter needs changing.
  11. bmcdaniel
    bmcdaniel Senile Member
    You don't mention how big a shot you're running. I ran a 150 shot for about twelve years just using a mechanical Carter street pump, very similar to the old Boss 302 pumps. Even with a 347 it had no problem supplying the carb and the nitrous plate. But you should run a fuel pressure switch that turns off the nitrous if the fuel pressure drops too low.
  12. garrettmuir1227
    Temecula,CA
    okay ill take a look at a carter too then... right now i have an edelbrock mech pump.
