mustang 2 front suspension
Discussion in 'General Maverick/Comet' started by maverick88tc, Nov 22, 2009.
  1. mav1970
    The Cleveland has a front engine plate
  2. Bryant
    the location of the inner sockets on the rack and pinion is very important to the location of the controle arms. if the controle arms are moved out or in from the factory locations the rack and pinon would need to widened or narrowed, or bumpstear will become evident. im going just assume that the crossmembers all keep the factory mounting locations and are just different to fit the different cars.
    the lower controle arms on a stock m2 or pinto are alot like the mavericks. they use a strut rod that goes from the arm towards the rear of the car instead of the front of the car. it also has the spring siting on it. so if you used stock controle arms you have to either use the maverick strut rod that was asked about earlyer or create some sort of custom mount or strutrod.
  3. Jamie Miles
    Alto, GA
    I've had a few
    Those strut rod eliminators just don't do it for me. Probably fine for a car that only sees a couple of thousand miles of weekend cruising a year, but whatever I put on my car would have to stand up to the rigors of hard, daily driving, and I'd expect it to last at least 100,000 miles without needing any major work, and that's driving over rail road tracks, speed bumps, you name it, every single day. Those look like a weak point.
  4. maverick88tc
    maverick88tc Member
    athens tennessee
    73 maverick grabber stock 460 s475 turbo
    ok i just measured a mustang frame and it measured 26 1/2 so are they the same the guy from fulltilt said the mustang kit is basically the same whatever that means
  5. 71gold
    all these questions and people giving their opnions to how they think it will work is why i went with...Rod and Custom...RC 107 kit... everything was there...just opened the boxes (painted the parts) and bolted them on...:thumbs2:
    3 days and it was ready to...:chirp:
    ...Frank...:Handshake...
  6. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Mustang 11 suspension kits
    Hello :
    I installed a RC107 Coilover setup on a 75 Comet last year and everything fit just fine. I tweaked the motor mounts a bit and added a couple of braces where I thought I might need them and I also reinforced a couple of other areas to the sub-frame connectors we also installed. I can recommend the kit and the people. They are very knowledgeable and helpful and KNOW Mavericks. I built my own Kit 10 years ago for another Comet , but if this kit was available THEN .. I would have it on THAT car.
    Look on page 16 of Mustangs and Modified Fords magazine (This issue)for their ad showing the kit . Everything is there including the BOLTS and NUTS which are not shown . This kit also has power steering and the shaft for your connections. I'm going to bring both of these cars to the NPD All Ford Show in Ocala , Florida in the first week of January of next
    year if anyone is interested in getting a closer look :thumbs2: Cometized CAMEO
  7. maverick468
    maverick468 Member
    Freeport, Illinois
    1970 maverick 468 ci.
    Its just that the header is right in the way.
    I guess I could have the header custom made so it would be a straighter shot. It's just the headders alone were $500.00 and I didn't want to cut them.
    Im sure it would be the same with any other kit because the motor and headders are so big.
  8. maverick88tc
    maverick88tc Member
    athens tennessee
    ok so i bought the full tilt crossmember and the spindles and 11 inch brakes from ebay and someone is giving me controll arms springs and a rack
  9. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    and some welding.....:Handshake
  10. 71gold
    welded the crossmember in...
