Mustang Cowl Vent Cover
Discussion in 'General Maverick/Comet' started by texasjack, Feb 1, 2009.
  1. coutangman
    coutangman Member
    Charlotte, NC
    I used a magnet type made with the Cougar logo on it on my daily driver '69 conv. It keeps leaves and water out of the cowl while at work. It also stays on at highway speed. I have used it for 3 years so far.
    Jim
  2. oldfordguy
    oldfordguy Banned
    canton ct
    72comet gt
    cowl cover for Mustang or Maverick or Comet
    I make cowl covers out of vinyl coated rubber that work very well for Mustangs 60 thru 65 Comets and Falcons as well as Maverick and 71 thru 77 Comets, They are sold thru Ebay, Many sold with no problems, just follow instruction. Search Ebay under Magnetic cowl cover, :thumbs2:
  3. oldfordguy
    oldfordguy Banned
    canton ct
    72comet gt
    Cougar cowl covers
    I sell Cougar cowl covers on Ebay also. :thumbs2:
  4. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Leaking Cowl Vent
    As I stated before I covered my vents with fiberglass prior to painting the car.
    It works great and I am sure the magnetic works also.
    After the mod I went to a wrecking yard and took the squiters off an Escort then drilled two holes in the hood and installed the squiters and new hoses.
    I had to use squiters off a Ford because if I put an gm part on a car the engine and tranny would surely fall ut on the ground.
    gm the American Yugo!!!!!!!!!!!
    Texasjack
  5. 1973Maverick357
    Cookeville TN
    You have any pictures of your cowls?
  6. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Cowl Leaks
    No, but I can take some when it is day light.
    Texasjack
  7. darren
    :rofl2::rofl2::rofl2:
  8. greenwa1
    greenwa1 Member
    El Paso Texas
    72 Comet GT, 71 Maverick
    Thanks, did the search on ebay and they have them for Mavs and Comets also now.
    Just a dumb question but isn't the cowl to get fresh air inside the car for such things as defrost? So you wouldn't want to keep it covered up all the time if you drive your car a lot right?
  9. Rando76
    Rando76 Member
    Claremore, OK
    Yes it is a fresh air vent, but remember that you have not covered up the cowl vent DRAINS. So, you should be pulling air through them which would essentially be from under the fender.
  10. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Windshield Nozzles
    Here is a pict of Escort nozzles on my Mav. I offset them about an inch to provide better cleaning. This is truly a no brainer mod.
    I agree the vents provide fresh air for defrost but the also provide fresh water for the carpet and floorboards.
    My defrost works. If it gets bitter cold (below 40) I will not be driving theMav.
    Texasjack
  11. Rando76
    Rando76 Member
    Claremore, OK
    No pic? :hmmm:
    Did you seal up the holes under the windshield trim?
  12. CaptainComet
    greenwa1,
    If you set your air on Max, it just recirculates the cabin air and cools it, no fresh air gets mixed in. I suspect that heater and defrost work the same way.
  13. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Knowing I'd get rained on during my trip to Biloxi this last week I preparred the car the best I could. I used a magnetic cowl cover, weather stripped the wipper holes, rtv'd the windsheild drain holes, removed fender and modified drain so that water did not back-flow into the cowl and somehow, I still got soaked. This coming winter, I will be removing my interior and cutting out the underside of the cowl to come up with a patch/filler panel of sort.
  14. oldfordguy
    oldfordguy Banned
    canton ct
    72comet gt
    cowl vent cover
    hey Texasjack ,If you want a cover for a Maverick I make them and sell the m on ebay , they are also available for Falcons and Mustangs,as well as early Comets, I make them and they work great they are made of vinyl coated rubberand stick with a magnetic grip,will not come off at race speeds. much bettr than plexiglass. made over three hundred so far in the last 6 years,look under cowl cover magnetic or Maverick or which ever car you need. thanks for listening
  15. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Vent cover
    Thank you for your offer but I have fiberglassed over my vents and had the car painted. It does not leak.
    Thenk you
    Texasjack
