mustang trans cooler lines????
Discussion in 'General Maverick/Comet' started by chicago74mav, Feb 16, 2015.
  1. chicago74mav
    chicago74mav Member
    chicago
    1974 maverick grabber
    couldn't find any 74 maverick trans lines and I bought a set new 71-73 stang c4 v8 lines. Anyone think its gonna work?
  2. Acornridgeman
    Wisconsin
    Would think with a little tweeking it should work. After all, there is not much difference in the 2 set ups.
  3. 71Mavrk
    71Mavrk Member
    Nevada
    chicago74mav likes this.
  4. chicago74mav
    chicago74mav Member
    chicago
    no I got the ztc7101 :/ gonna contact seller and see if he shipped yet ill cancel
  5. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    I ended up going to autozone and picking up regular lines and bending them up. pretty easy. I have a rubber section right by the radiator.
  6. chicago74mav
    chicago74mav Member
    chicago
    I just dropped 75 plus shipping on the ones that 71mavrk provided the link for... Stainless steel.... I gave it a thought using rubber hose but heard a lot of bad stories hows yours holding up
  7. Craig Selvey
    Stainless steel is a very HARD line. You will probably need to tighten...then loosen.....then tighten.....then loosen several times to get them not to leak.
  8. chicago74mav
    chicago74mav Member
    chicago
    good tip if it leaks when hot I bet itd be easier to snug down warmed up to huh
  9. Craig Selvey
    The harder steel takes more to get it to "smush" and seal. LOL
  10. chicago74mav
    chicago74mav Member
    chicago
    smush lol
  11. 71gold
    I have 5/16 hydraulic hose on mine...not a problem. I use their barbed shark bite style fittings (no clamps).
    my transmission cooler is mounted beside the gas tank (stock muffler place).
      File size:
      169.7 KB
  12. chicago74mav
    chicago74mav Member
    chicago
    only issue with all rubber lines is that they retain more heat than steel making trans run that much hotter
  13. 71gold
    mine is the opposite...I took the fan off my transmission cooler because the lines to and from the cooler acted as a heatsink and cooled the fluid ...:yup:
    I don't know if it's the material the hoses are made from or what.
    I thought the location of my cooler would be a problem is why I chose the one with a fan. after install I never used it.
  14. chicago74mav
    chicago74mav Member
    chicago
    Wanna sell the fan? Lol
  15. 71gold
    hadn't thought about it....let me check and make sure I have it.
