mustang trans cooler lines????
Discussion in 'General Maverick/Comet' started by chicago74mav, Feb 16, 2015.
  1. chicago74mav
    chicago74mav Member
    chicago
    1974 maverick grabber
  2. 71gold
    found the fan...7"X7"...PM me a # and I can send you a pic...
  3. chicago74mav
    chicago74mav Member
    chicago
    is starting a conversation same as pm? I can't find the pm option lol
  4. Krazy Comet
    Dismal Swamp
    Lot of factory installs used 6-8" length of hose to couple the lines to the cooler in radiator...
    As far as run hotter maybe .02*F...
  5. chicago74mav
    chicago74mav Member
    chicago
    no doubt... That also benefit absorbing shock to line however im saying if the entire cooling lines are rubber... Not just the ends
  6. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    Ive used hydraulic hose on many of my engine swap cars. I try to find hose barbs that fit in the trans and the radiator and just use a good hose clamp. Makes running and hiding lines alot easier. Never had any problems.
  7. chicago74mav
    chicago74mav Member
    chicago
    yea I went with OEM stainless lines...
  8. mojo
    Interested in why you put the cooler in the rear of vehicle?
    Hardly anyone uses hoses the full length from the trans to the radiator/cooler. I run a few feet of rubber hose to my radiator and external trans cooler.
  9. chicago74mav
    chicago74mav Member
    chicago
    a
    are you running the aux cooler in sequence then? Did you have to modify your stock lines?
  10. mojo
    I am running a aux cooler. I cut the lines close to the radiator and ran the aux cooler in series w/ the radiator.
    chicago74mav likes this.
  11. 71gold
    mine comes out of transmission straight to the cooler. the rear area was a convenient place.
    yes...
  12. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I took my old lines to NAPA and had a set made. Worked perfect the were around $75.00.
