mustangsunlimited I6 header help
Discussion in 'Technical' started by chevyandford71, Feb 22, 2012.
  1. Sherrod
    Sherrod Member
    73 mav 250
    can anyone confirm if these work or not, i just bought a pair but the engine is out right now while doing body work...
    Thanks
  2. cody674
    cody674 Member
    1972 Ford Maverick
    my car has got a 76 200 and it has got the long water pump
  3. 71gold
    what did you...buy a pair... of?
    now would be a good time to install them (it) and see if the starter/bellhousing is a problem...:yup:
  4. Jamie Miles
    I've had a mustangs unlimited header on my '72 since 2006. I had to cut a pie section out of the area leading up to the collector in order to move the collector over about 1/2" because it was hitting the bell housing on the '74 250/c4 I had in there at the time. I ran it on the 250 for about a year then switched over to a '71 200/c with no problem, then last year I switched over to an '80 200/4 speed in which it also fit without problem. I don't remember which model my header is, but it was for a 65/66 Mustang with a 200, single out.
  5. Sherrod
    Sherrod Member
    73 mav 250
    So no shock tower issues? That's the only thing I'm really worried about...
