My 1970 Maverick Project
Discussion in 'Maverick/Comet Projects' started by Byron, Nov 2, 2011.
  1. Byron
    Byron Member
    Arlington, TX
    1970 Maverick Grabber
    Some more progress. Got the front steering/suspension installed, upgraded to 5-lug disc brakes from a 77 comet, also added roller bearing spring perches and a 7/8" sway bar. Suspension and steering is stock otherwise, but everything rubber has been replaced. Wheels are 15x7s from US Mags.
  2. John Holden
    John Holden Member
    NJ
    How heavy are those us mags wheels? They look nice and will give it a nice period correct look while still being and upgrade due to the size. What size are you putting on the back?
  3. Byron
    Byron Member
    Arlington, TX
    Yes, I am quite pleased with how they look. With the tire mounted, they weigh 38 pounds.
    Not sure what I going to do in the back yet. I still have to change out the rear end first since it's still got the 8" with 4 lug axles. I keep changing my mind on whether to go 8.8" or 9".
  4. Byron
    Byron Member
    Arlington, TX
    Driver's seat and Steering column
    Got the driver's seat and steering column mounted. Decided to splurge and get a fancy aftermarket Ididit column. Probably not worth it, but I think it looks cool.
  5. mercgt73
    Looks good! (y)
  6. mojo
    Vry nice! It's the first Mav I've seen w/ a tilt-column. I like it. :thumbs2:
    Trying to figure out how u have that clamp fastened to the dash in pix #3?
    1.) Which column #?
    2.) What abt wiring issues? Are most of those columns set up for GM hook-up?
  7. Byron
    Byron Member
    Arlington, TX
    The mount is just screwed bracket that holds the brake pedal and the original steering column. Some drilling and grinding was required to get it to fit.
    The column is Ididit part number 1120280010
    Yes, it is GM wiring. I am going to be doing a complete custom wiring job, so that doesn't bother me too much.
  8. mav1970
    The column looks good :thumbs2:
  9. mojo
    Ok on the complete wiring job. Thks for the info. At some point Im thinkin tilt column. Im following ur progress - Thks for the pixs...(y)
  10. Bryant
    ididit is supposed to be offering ford plugs on the columns now. looks really nice, has me thinking of going that rout.
  11. Byron
    Byron Member
    Arlington, TX
    Rear End Installed
    Finally got new leaf springs and 9" rear end from Quick Performance installed. Also a lot of POR-15.
