My 1972 Comet GT Clone
Discussion in 'Maverick/Comet Projects' started by Krazy Comet, Oct 11, 2013.
  1. Krazy Comet
    I didn't, wasn't there when I bought car...
  2. Paul Masson
    1971 Grabber
    Progress looks GREAT, Tom!! That power steering pump looks perfect in Chesapeake Blue!!!
  3. Krazy Comet
    Paul Masson likes this.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Yeah, awesome-looking Comet.
  5. Krazy Comet
    Thanks guys...
    The rear is almost finished, still have to realign bumper... Sets in too far on D/S car appears straight but I suspect it's been bumped sometime in the past...
    Last night I did the one job I was dreading most, installed the driver door trim... Would be a piece of cake without the window in place, but with it in, it's all but impossible to access the nut that holds the clip at rear of door...
    Today I'll install mirrors, sill plates and seat belts... Also the back cover on water pump is weeping, looks like I'll have to pull it off and tighten cover...
  6. Paul Masson
    1971 Grabber
    Looks SWEET, Tom! When do we get a FULL shot of the car??? :D
  7. mojo
    Real nice job on that restoration. Is the tail panel painted semi/gloss/satin? When I get around to mine I am going to change from the flat black.
  8. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    Krazy- That looks awesome. You can come to Idaho and help me with mine now ! ;)
  9. Krazy Comet
    Yes it's a semi gloss black, I'll find out exactly what paint was used...
    Well 'ceptin' for the mirrors and rear, it doesn't look any different than the second pict in thread... I'll be ordering the stripes soon, then it'll have more of a performance look...
    Thanks but I've never been to Idaho...
  10. Tannersg1
    Tannersg1 Member
    Classified
    That looks great! One question...why did you run the transmission vacuum line from that spot on the manifold and not the one below the carb base? I'm not knocking your decision but I'm making sure I installed mine right by connecting it below the carb base.
  11. Krazy Comet
    It's a temporary hookup, just a old line I had in a box of odds and ends... I'll connect the PCV valve to the vac source at rear of carb and install a factory vacuum tree on the intake as orig for HVAC and trans modulator...
    The original hookup caused a lean misfire on #7 cylinder, too much air from PCV entering that cylinder... Something like the trans modulator, or HVAC doesn't create a vacuum leak(or at least aren't supposed to), so won't cause A/F ratio issues...
  12. Krazy Comet
    Will this do for now?
    Still standing on it's toes in front, but I believe it's settled some...
    Tannersg1 and Paul Masson like this.
  13. Mel Moeller
    Twin Falls Idaho
    Awesome Tom! :thumbs2:
  14. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Oh man that's a nose-bleeder! I love the car though.
    You have done an awesome job on it.
    :tiphat:
  15. Paul Masson
    1971 Grabber
    Looks GREAT, Tom!! Now I can sleep well at night... :D Really like the stripe!
