My '71 Build
Discussion in 'Maverick/Comet Projects' started by xpsnake, Apr 24, 2011.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Back is doing well. Broke out my buddy's Rigid 37 degree flare tool and terminated one end of my hardlines for the fuel. From these end fittings I'll be using Earl's Vapor Guard Rubber hose to run over to the in-tank fuel pump. I'll have to do another set on the other end soon.
    I definitely almost forgot to slip the fittings on before the flare. Caught myself in time.
    Ronald Hopkins likes this.
  2. xpsnake
    xpsnake Bruce
    Continued work on the fuel lines. Going to have to cut down the front lines - I did too complicated of a bend and now I can't slide the collar up far enough to get the flare tool locked in. Bonus shot of the stamping on the bottom of my driver's rocker panel. For the years of daily abuse this car got, it's still pretty clean.
    Mustang1989 and mojo like this.
  3. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    I've used that green tubing. It's good stuff, corrosion resistant and bends easily.
    xpsnake likes this.
  4. xpsnake
    xpsnake Bruce
    Had to cut back the lower fuel line in order to clear the factory pass-through and be able to get wrenches on the fittings.
    I also cleaned up the factory tie down plates graciously left on the car by the Paragould, AR dealer in 1971.
    Should be able to start mocking up the vapor guard hose soon.
    Mustang1989 likes this.
  5. TeeEl
    TeeEl Senior Member
    Colorado
    That is nice...
    :thumbs2:
  6. Earl Branham
    Lugoff, SC
    Glad you are getting to it. I've never seen it up close. Are you going to bring it to Bowling Green in July?
  7. xpsnake
    xpsnake Bruce
    Not sure, Earl, just depends on how the next quarter goes.
    Small project this weekend - cleaning the factory tie down bolts. I soaked them in Ospho, wire wheeled, and then brushed with Ospho once more. Need to spray a little paint on the ends and I'll be done.
  8. Earl Branham
    Lugoff, SC
    They look great. My tiedowwns were long gone when I got the car. Never thought about trying to find some, but it couldn't hurt. BTW, my car looks great, and it should be done by the end of next week. I'll get pictures for ya.
    Catch you later,
  9. mojo
    Hi Earl, hope all's well! You going to share pictures on the forum -- so we can all admire? BTW, what are tie downs you guys talking about -- not familiar. Merry Xmas /Happy New Year -- You and Bruce..
    :christmas:
    Earl Branham and xpsnake like this.
  10. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    They are brackets at the rear of the car the factory installed to tie the cars down during transport. 20201216_044853.jpg
  11. mojo
    Ok, I thought that may have been what they were talking about. Somewhere along the way it/they have been removed from my car.
  12. yellow75
    Tillamook Oregon
    They were suppose to be removed at the dealership there was a sticker where the rear license plate was suppose to go instructing dealers to take them off . They only came on 70-72 not sure about 73 model year
    xpsnake likes this.
  13. RMiller
    Kennewick, WA
    They're a great feature to crack your head on!
  14. xpsnake
    xpsnake Bruce
    Finished cleaning up the tie down plates and bolts and re-installed. Now I can start on finishing the fuel line that runs in front of the driver's side plate. I also got a ORB low profile plug for my unused port on my FPR. I decided to try out hotrodfuelhose out of Canada, and at first glance the hose and fittings appear of good quality. I am using a 90 and 180 on the TBI in order to direct the fuel back to the driver's side tower where the FPR is.
    I bought two of the Scott Drake oil pressure extension pieces that are tapped for the idiot light and an aftermarket electric or manual gauge. Both of the ones I received had some shavings inside the shaft. Pays to inspect your parts, even new ones.
    I needed a win so I also got the taillights and quarter extensions off the shelf and bolted them on, just to give me a sense of accomplishment. I'll need the lights on there in order to figure out where my battery switch will end up.
  15. xpsnake
    xpsnake Bruce
    Mocked up the clutch master reservoir bracket today. Had to dig my wiring harness out to ensure it would clear without issue. Mounts to the two pedal box bracket bolts about the brake master. Needs a little finishing work and isn't the most pretty - but it is functional. I'll take it.
    gator25, Mustang1989 and mojo like this.
