My '71 Build
Discussion in 'Maverick/Comet Projects' started by xpsnake, Apr 24, 2011.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Been working on the fuel line routing. I originally was going to come straight across from the apron, but there is no strain relief in that design, plus it looks odd to me and is in the way. I had already put a 45 hose end on before I realized this. Fortunately, my buddy suggested going down near where the factory fuel line runs and and lines up pretty good.
    I need to make one or two brackets to hold the line clamps and finish the hoses and I'm done.
  2. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    What if you built some sort of loop to capture the fuel line, mounting it with the bolts which hold the fuel pump block off plate?
    xpsnake likes this.
  3. xpsnake
    xpsnake Bruce
    Jaybee likes this.
  4. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Perfect!
  5. xpsnake
    xpsnake Bruce
    I got a cheap boroscope as a gift this Christmas, while it is not super hi definition, it sure is handy for creeping around and checking out tight spots. Here are two shots of the clearance between the fuel hat and the sending unit and my trunk floor. There are no clamps on the fuel hat hoses yet. Pretty neat.
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Resolution looks great to me, that would be a handy tool to have!
  7. xpsnake
    xpsnake Bruce
    Can't wait for when I need to find something I dropped out of sight - it came with a hook and magnet attachment too!
    71gold likes this.
  8. RMiller
    Kennewick, WA
    Perfect! What's the brand name?
  9. xpsnake
    xpsnake Bruce
  10. RMiller
    Kennewick, WA
    I can forgive the flaws for that price, not like I would use it daily! Thanks for the link!
    xpsnake likes this.
  11. 71gold
    I can see you have a fuel line...upside down...:yup:
  12. xpsnake
    xpsnake Bruce
    That is the return line, Frank. You want the fuel to stay oriented in the hose the entire way so it is reversed.
    71gold likes this.
  13. xpsnake
    xpsnake Bruce
    Moved the clutch master up a couple of inches to unkink the line.
    Mustang1989 likes this.
  14. Mustang1989
    Mustang1989 Member
    Corpus Christi, Tx
    1994 Chevrolet 383 Silverado
    Very nice work on that Bruce!
  15. xpsnake
    xpsnake Bruce
    Got out of my comfort zone and tapped the modified AJE Foxbody lowering spindles for the caliper brackets today. I did it on the car, two of the driver's side bolts aren't perfect, but they'll do. After that I got much better and everything threads in nice and flat. AJE does not thread these laser cut holes because folks use differnent brake kits with different threads, they say. Either way, I tapped to 3/8-24 and the "plunge cut" for the laser ate into my thread area. It was also challenging to work the tap handle with the spindle in the way. I'm not a fan of tap sockets for spots like this, as the cut in the threads caused chips to bind up and make it very slow work. Got to work with what you have, I could always back these up with some nuts if I see the need.
    As an aside, I also tried the late model Ford electric trunk release conversion and I ran into an issue that might be specific to early models. The trunk latch area has two divots on the sides that I tried to route out with a nibbler, but still prevented me from aligning the latch. I could shave them down or cut them out and it might fit. I may look into the thunderbird unit as well.
    yellow75 likes this.
