My '71 Build
Discussion in 'Maverick/Comet Projects' started by xpsnake, Apr 24, 2011.
  1. TeeEl
    TeeEl Senior Member
    Colorado
    I've been thinking that I'd like to get one, but also thinking that in the event of a rollover, gasoline would dump out of the fuel bowls on the carb anyway, in which case, how much is the vent valve really helping (?). The vent on top of the tank is a tiny pin-hole, and I still have the original vent tube running up to the firewall (but no vapor canister anymore). A hose runs from that out through the fender apron to the wheelwell...
  2. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    If I still had the line going to the front, I wouldn't have bothered with this. I have an EFI setup and the way my tank and vent are set up, it made the most sence.
  3. xpsnake
    xpsnake Bruce
    This is a project for "Mav2" as she's been come to be known. We took a 1200 mile road trip to the GatherUp and a family funeral, going from the St. Louis area, to Bowling Green, KY, through Cincinatti, up north of Dayton, OH, and then back down through Louisville to home. The only noteable issue we had were a minor transmission issue and ... whenever we got caught sitting still in 100+ degree Farenheit temps, the water temp would start to creep, too fast for my liking.
    The car has a reproduction copper/brass, 3-row, 144 core, 20 1/4 inch core width x 16 3/8 inch core height x 1 3/4 inch core thickness radiator from U.S Radiator #8005-1HH and a Daniel Carpenter reproduction Mustang fan shroud #8146-6. Both are for a 1970 Mustan 302, standard cooling. At the time I was running a 4 blade direct drive fan on a 1" spacer, right about 50/50 on the edge of the shroud. We tried changing the spacer at the meet, with no marked difference.
    I started doing some math, and this is what I came up with:
    • Derale 17117 Heavy Duty Fan Blade Series 1000 17" Steel Clutch Fan Standard Rotation
    • Hayden Automotive 2711 Premium Fan Clutch
    • 5/16"-18 x 5/8" Hex Cap Screws (these are a specific size, plus lock washers, to mount the fan to the clutch)
    • I also need some, I think 7/8" bolts to mount the clutch to the pulley/water pump
    I actually originally started with an over 18" fan blade off an early Thunderbird, but it was just too close to my not-centered shroud for comfort.
    With the original setup, in 95+ degree heat, the car would reach 200 in under 15 minutes. With this setup, it idled for 40 minutes holding at 200.
    plynch likes this.
  4. xpsnake
    xpsnake Bruce
    Finished up the lokar throttle cable kit by adding a short extension to my pedal to allow for more of a a straight pull from the firewall port.
    Earl Branham, 71gold and Rasit like this.
  5. xpsnake
    xpsnake Bruce
    Slow progress. Used my new transfer punches and some scrap aluminum to making a mount for the "main harness" circuit breaker that power the factory harness and my relay panel.
    Mustang1989 and RMiller like this.
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Looks clean, one of the more tedious jobs on a car....wiring!
    Earl Branham likes this.
  7. Mustang1989
    Mustang1989 Member
    Corpus Christi, Tx
    1994 Chevrolet 383 Silverado
    Takin' the time to make it a professional job. Nicely done.
    Earl Branham and RMiller like this.
  8. xpsnake
    xpsnake Bruce
    Ages ago I got lazy and cut the rear harness connector below the 1/4 window to get it out of my way. I finally reconnected it with a Molex connector, came out great. I also replaced the fabric wire wrap with some new, modern, wrap. I also replaced all of the lights with LEDs, as I've done on our other cars.
  9. xpsnake
    xpsnake Bruce
    Fixed my ignition switch today. When I installed the NSS I checked the circuit and was getting 20-100Ω of resistance.
  10. Earl Branham
    Lugoff, SC
    Getting closer!!
  11. xpsnake
    xpsnake Bruce
    My speedometer cable was laying on the new exhaust, so I fabbed up a small bracket to hold it and put a strip of fireflex over it. Should be just fine now.
  12. xpsnake
    xpsnake Bruce
    I also added a fuse box buss bar for later use. Should have taken more time to center it up, but its plenty functional.
    Earl Branham and plynch like this.
  13. xpsnake
    xpsnake Bruce
    Finally got around to putting in the starter/alternator power bulkhead. Came out nice.
  14. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I realize this is an old thread...but wondering if you could provide a measurement from the fan pulley mounting surface to a fan blade at the closest point to the radiator? I want to run a clutch fan but have a 3 row aluminum radiator and not sure if the fan will clear the radiator.
  15. xpsnake
    xpsnake Bruce
    I sure can. The car is in winter storage still - been busy. When I get it out I'll measure.
