My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. Dave B
    Very nice! That's the way I'm doing mine, I'm not a fan of seeing them hang down under the car.
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Well the way I am doing this it not only raises the connector so it is less visable, they will make it much stronger then just welding them in as they came(like I mentioned above I also need some extra room in the rear to clear my Cal-Trac's)..... For one I am increasing the weld are considerable in the rear and some in the front, but the key in the rear is it will now tie two different sections of the rear torque box and the rear frame together with more then just spot welds..... Putting it through the floor and welding to those areas does increase strength being that the floor itself is a big part in the structure of a unibody design.....
    Not to mention you haven't seen everthing I am going to add yet..... Stay tuned for more.....
    I think you get it a little better.....
    I probably should have just made them in my case with deciding to go through the floor, but I purchase these because they wern't very expensive and figured I could easily modify them if necessary.....
    Thanks and I definately don't like them hanging down too low either.....
  3. Dave B
    Years ago, they tubbed a Maverick in Hot Rod magazine, they slotted the floors where the rear rails went, so the extensions were half above and half below the floors, I always like the way it looked.
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I finished fitting the driver side connector this morning and welded it in.....
  5. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    Very Nice (y)
    There's an interesting article in this month's Muscle Car Review about "silhouette-cut" subframe connectors done by U.S. Car Tool. I think they mostly do Mopars though. Sure would be nice they were made for our cars.
  6. Bossed
    Bossed Member
    Fort Barnwell, NC
    70 Grabber, 70 Maverick
    Frank, your work is awesome, I look forward to seeing whats next. (y)
  7. mojo
    Man that looks like it came from the factory. It looks better than if it came from factory. I assume u have several restorations in the past. :thumbs2:
  8. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks.....
    Thanks.....
    and thank you too.....
    Yes I have built quite a few cars in the past.....
    Here's a few I have pic's handy on.....
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I added a piece of 1"x 2" from the connector out to the rocker right along the front plate of the torque box..... I also started to fit the 1/8" floor plate for the roll bar, but it looks like I can't finish it until I get the floor sheetmetal in..... So next I started to fit the pass side connector..... Got the floor marked and cut to clear the connector.....
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Had a side job to knock out Wed morning, but I did still manage to get the pass side connector close to where it needs to be..... A little more trimming in the morning and i will be able to weld it in.....
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I got the pass side connector fitted and welded in this morning.....
    The weld on the outside rear of this connector doesn't look very good(you can see it in the last pic), had problems with the same weld on the driver side..... For one I pretty much suck at welding upside down and then you add a bunch of galvanize or other metal treatment it just adds to the problem..... I am going to have to roll the car up on it's side and fix these.....
  12. mojo
    What's wrong w/ those welds? The most of them look OK to me. The only one I see that may need some attention is the last pic near the leaf spring mount. It's kind of hard to tell the way the light is reflecting from it.
  13. CaptainComet
    pffffttt ... his upside-down welds look like my right-side-up ones ... :biglaugh:
  14. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    My thoughts exactly!
  15. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    The last pic is the one I am talking about..... IMO it pretty much sucks, altough it will probably hold fine.....
    I am just not sure how to respond to this..... :huh:
    :cry:
