My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. doncraft
    doncraft Member
    Monroe WA
    1970 maverick 68 Ranchero
    Frank
    I've been a gearhead most of my life, but I'm new to mavericks and what you have done here is an outstanding job of craftsmanship and documentation for those of us who don't know all the little things that are unique to these unibodys. It was about 5 yrs.that I raced full sized stock cars here at Evergreen Speedway in Monroe so I have the basic fab skills needed to get the job done (not quite as good as yours) so what you have done is to give those of us that are in the same boat a heads on a lot of things that may have taken at least a few years to learn the hard way. So I personally want to thank you for the great job that you have done here so far and I hope that you keep up posting your progress and I will be following closely and also using the thread as a reference tool.
    Thanks again
    Don
  2. mav1970
    Funny you should mention the name of your track as all of the pavement stock cars that I have built over the years were raced at a track called Evergreen Raceway here in Pennsylvania. I went to Tacoma back in 05 and I wanted to get to your Evergreen but ran out of time. Maybe someday. :tiphat:
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks.....
    No I am not going to put a door bar in the pass side atleast for now(swing outs don't really add that much to the car anyways).....
    My shop needs to be cleaned desperately, and once I get this rollbar mess done it will get cleaned.....
    Thanks Don, and if what I post in this build helps you and others I am more then happy to do it.....
  4. doncraft
    doncraft Member
    Monroe WA
    Frank
    thanks. Any hints and tips you can think of would be appreciated. Great work.
    Don
  5. doncraft
    doncraft Member
    Monroe WA
    Bob
    Thats cool I didn't know that there was another Evergreen Speedway. You can go to evergreenspeedway.com and check it out. It's off season so the site is out of date and there changing management for next season (it's got to be better) it's a cool track it's a 5/8 with a 3/8 and a 1/5 with a paved infield for figure 8 and they do 1/8th mile drags on th front stretch not sure where they do the drifting but thats done here to, so it can be a busy place in the summer. Is there a web site for your track I'd like to check it out?
    Don
  6. mav1970
    It was called Evergreen Speedway from the 40's until 2000(Jimmy Spencer's family ran it from 77 till 82) - then it bacame Mountain Speedway but for the last 2 years it was called Sundance Vacation Speedway (kind of hoaky) as they sold the naming rights. I guess it's going back to being called Mountain Speedway for 2011. Here's the link to their website and if you go down the left to the Kevin Green Photos link you can see pictures from 2010.
    http://www.mountainspeedway.com/
  7. SenseiWally
    SenseiWally Member
    sunrise beach ,mo.
    1974 grabber
    Hey Frank what did you do with the seats that where in the car when you started this post I would like to try and buy them if possible.
  8. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    They are long gone, I sold them locally shortly after buying it.....
    Tuesday morning I got a little time in on the car..... I finished the swing out side bar..... Then got a little more work done on the pass side seat mount.....
    Some pic's of the swing out.....
    and the progress on the seat mount.....
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I got a little more done this morning.....
    Cut off and end capped the back inside tube of the seat bracket.....
    The 2 stud plates for the inside mounts are ready to be cut off.....
    and got the front inside reinforcement plate made, welded in, marked up and drilled.....
  10. starsky74
    starsky74 Technician
    Hackberry Louisiana
    that swingout bar looks killer:thumbs2:
  11. SenseiWally
    SenseiWally Member
    sunrise beach ,mo.
    1974 grabber
    Do you plan on painting the roll cage or are just gonna put foam on it?
  12. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    It will get painted with Hammered finish black.....
    Finished the pass side seat mount today..... Also welded up all the old extra seat mounting holes in the pass side floor and shifter mounting holes in the top of the trans tunnel..... Then I got the new shifter mouning stand off's tacked in place..... Tomorrow hopefully I can finish mounting the shifter and get all the seat belt mounting tabs welded in.....
    Here's the seat mount in place.....
    The holes in the tunnel welded up.....
    The seats both in place with the shift mounts tacked in place.....
    Here's a close up of the threaded shifter mounting stand off's I made.....
  13. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Welded in the shifter mounts, upper seat mounts, shoulder harness tabs and a reinforcement plate for the crotch strap mount..... I need to make some threaded stand off for the lap belt mounts this week.....
    Here's the welded shifter mounts.....
    The upper seat mounts and shoulder harness tabs.....
    and the reinforcement plate for the crotch strap mount, the plats is also plug welded in 3 places directly to the subframe flange.....
  14. Gary B Jones
    Gary B Jones Member
    Augusta Ga.
    Still looking
    OK Good Job...I'm starting to feel a little safer now :) Be sure and plate those seats in case of a REALLY BAD CRASH they will stay mounted....Great Work. I'm going to be in Largo one afternoon this week. If you want to go to a shop and see about 3 Million worth of Vintage racecars PM me your cell number or an E-mail address. You will love this place....GJ
  15. SenseiWally
    SenseiWally Member
    sunrise beach ,mo.
    1974 grabber
    I'd feel safe in anything this guy builds he really knows what he is doing...only wish I had his talent!
