My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. Timekeeper
    Timekeeper Member
    1971 Comet Gt
    Nice Project! Good Looking Car!
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Yes sir, and he is a very cool guy.....
    I thought about building one, but didn't want to put the effort into it..... Then I was talking to my boss and he said I could use this one, and it will make things much easier when working under the car just for then reasons you stated.....
    I got all the front suspension and steering removed this morning..... Then I worked on stripping the rear floor area(under rear seat), I think it's easier to do on it's side and it needs to be done before the underside gets painted..... plus I want to make sure every bit of metal possible gets coated with POR15 paint.....
    Here's pic's of the susp and steering removed.....
    and here's the rear floor area so far.....
  3. mojo
    Rear floor area
    Looks like the floor has only some surface rust. Also, great lookin work so far. :thumbs2:
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks, and yes mostly some light surface rust back there that will be easily taken care of with the Por15.....
  5. mavmet
    mavmet Member
    Auburn WA
    1972 grabber
    nice work
    I have followed this project of yours from the beggining and it is an insperation to many of us that are in the middle of a maverick or comet project of our own but in my case with time being so short it is difficult to find time to work on my maverick but when after seeing this thread and watching your progress it gives me the extra push that i need to just get off my butt and do it so thank for the insperation and keep it coming you do some amazing work and you fab skills are some of the best i have seen in a long time that will be one awsome mav when it is done. Thank again.
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thank you, actually I haven't been getting much done since just before the holidays due to working too much which isn't such a bad thing the way it's been the last couple years..... However I am going to start backing off some on work hours so I can get some work done on this thing.....
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I got a little more done this morning..... Stripped the inner wheel houses in the rear seat area and started strippint the front of the trunk area.....
  8. Scrapper
    Scrapper Member
    This is a great build! Been watching from the beginning. Thanks for all the hard work in sharing with us. Looking forward to the rest to come
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    and thank you for the interest in my little project.....
    I finished stripping the inner fenderwells and trunk floor this afternoon(I will do the insides of the quaters when the car is up on the rotissorie and on it's side)..... Let me tell you what a tedious bullshiz job stripping that was..... Next thing is to make a couple adaptor brackets and get it mounted on the rotissorie.....
    Here's todays progress(the trunk floor is really solid looking with only a couple very minor surface rust spots starting in the seams under the sealer).....
  10. mav1970
    "LITTLE" project he says :rofl2:
    When is it going to get "BIG" :cry:
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Someday I might get serious and really tear this thing apart..... :bananaman
  12. mav1970
    If you tore it down anymore, you would have to strip it to it's molecules (y)
  13. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Went down this morning to start getting it ready to go on the rotissorie..... Removed the rear end housing and took out the driver side leaf spring with no issues..... Then the problem comes, the front bolt in the pass side spring is aparrently rusted in the sleeve in the spring bushing..... I got the sleeve to sping in the bushing and managed to get the nut off the bolt, but I can't get the bolt out because it's rusted in the sleeve..... Looks like I am going to have to cut the bolt to get it out, oh happy day..... I did get the rear shackle off the spring so I'll get the can on the rotissorie and turn it on it's side where it will be easier to get at.....
    After that adventure, I some pieces of material to adapt the rotissorie..... Next weekend I should be able to get it mounted and start working on the bottom side.....
    No pic's today cause there just wasn't really anything to take one of.....
  14. tazbm193
    tazbm193 Member
    florida
    ford
    I hope to do as well as you have done. That looks like a nice car. was it in running condition when you bought it?
  15. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    It was a running, decent driving car..... I drove it 48 miles home the day I bought it and haven't driven it sense..... and Thanks.....
