My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. tazbm193
    tazbm193 Member
    florida
    ford
    Your workmanship looks good, welds look solid. The secret to doing this work is to keep everything as clean as possible. Nice job.
  2. mav1970
    A true thing of beauty, Frank :thumbs2:
  3. SenseiWally
    SenseiWally Member
    sunrise beach ,mo.
    1974 grabber
    This post is just amazing you need to take all the info you have provided us with and create your self a How-To book and send it to a publisher somewhere who knows it might pay for your next project....just sayin
    I hope this post never gets deleted cause I still got alot of copy and pasting to do!!!!
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks alot.....
    and Thank you once again.....
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I don't know about the how to book, but thanks and I just hope some of this info is useful to others here.....
  6. mav1970
    Oh, I'm sure I'll have a few more "atta boys" left in me as more pictures come down the pike :)
  7. Recrdholdr
    Recrdholdr National Record Holder
    London Ontario
    I want a 70-73 Maverick
    Hmm Looks like the pinion seal was leaking just a little bit. ;)
  8. oztrucking63
    oztrucking63 New Member
    roach, mo 65787
    72 maverick grabber 401 9 inch brodix heads dart block strange frontend wilwood disc brakes 4 piston vented slotted rotors pro flow. 73 mercury comet 408 winsor rhs heads all forged eagle rotator 9inch 3.70s disc rakes c4 reverse manual pro flow nos.
    just sat here and read all 34 pages awsome input think i will back up and start over on my 72 grabber thanks frank
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thank you.....I finally got a little work done at the shop this weekend..... Sat I installed a new air line along the wall along with a nice water seperator/filter, I was tired of plugging directly into the side of the compressor and dragging air hoses all over the place..... Now I have 4 drops along the side wall of my shop which should make things much easier, plus no more fighting with getting water in the line..... I also tore down a C4 trans for a side job I have, got to fund this project somehow.....
    After a little clean up Sun morn I finally got back on the car a little..... I cut some rusty seams out of the pass rear fenderwell area at the front and rear where the outer and inner fenderwell panels come together.....
    Here is the front seam before I cut it out.....
    Here is the same seam after cutting away the unwanted area and cleaning it out, there was alot of loose rust between the gap in the opening here.....
    This is the same seam after welding it closed and initial clean up, still a little more to do here.....
    Here is the seam in the rear of the opening which is actually where the outer wheel house and inner trunk drop come together.....
    Here it is after I cut away the rust seam.....
    and here it is after welding and clean up.....
    This is the backside of the same seam inside the trunk after being welded.....
  10. mav1970
    So, you're really liking that rotiserie? :yup::yup::yup:
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Yes sir, it's making the kind of work I did today much easier to get at.....
  12. brickyard67
    brickyard67 Member
    lafayette,in.
    71 maverick
    were the drain holes plugged in these areas, mine were from a undercoating that was done right after purchase, thank god it came from Oklahoma where they have better than we get here in indiana.also if you look the rain drip gaurd behind your back side window look and see if there is a gap where it stops and chrome piece from window have a gap in so water runs down over wheel well when it rains or you wash it, beautiful job on repairs, love the rotisserie
  13. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    The drain holes were not plugged and there was no sign of water leaking from th rear 1/4 window area..... Mine just rusted between the overlaping spot welded seams that the tire throws crap at over the years..... and thank you for the compliments.....
  14. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Whoo hoo!!!!! I finally did something on the car today..... After the trans I just built for someone got picked up I pulled the car away from the wall, I was going over the area of the floor pan I cleaned up I noticed a weld I missed so I cured that problem..... That's about it for now, but one thing is for sure - No more side jobs for a while..... I'm still probably not going to get much done for a couple week though, I will be going to the NMCA race on Sat in Bradenton and the following weekend I'm going to Tenn for 4 days..... After that I really need to get some work done on this thing.....
    Here is the weld at the top of the tube.....
  15. DVCRobin
    DVCRobin Member
    Nashville, TN
    1976 Maverick
    Where in Tenn?
