My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. Mavman72
    Great job on the build man!!! It is nice to get to that solid color primer stage ain it...
  2. mercgt73
    Awesome work! They definitely look better all 1 color, even if it is primer. You have been answering my unasked questions so far, like "Do I Por15 THEN prime?" and "Should I weld this 1 thing in first THEN test-fit this other thing in second?". etc.
    Thanks! :yup:
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Touched up a couple spots of seam sealer in the drip rails this morning, also seam sealed all the seams in the floors and around wheel wells..... Then I started the wonderful process of blocking, did I mention how much I hate body work yet..... Forgot the camera so no pic's, not much to see anyways.....
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I finished blocking the roof and quaters this morning, then primmed it up again..... I got about 3 or 4 little spots to address, block/prime again and then a final blocking and it's ready for paint..... Almost forgot I lowered it on the cart yesterday morning so I could reach the roof without a step stool.....
    Here it is in the new lowered position with another fresh coat of primer.....
  5. Craig Selvey
    Can't wait to see it in paint. At your rate......Wednesday, right? :D
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I'm only working on it on the weekends so the earliest it would see paint is in 2 weeks, or possibly 3 depending..... I like to let it set up for a week in between just to make sure nothing odd shows up as a suprise because I was rushing.....
  7. mercgt73
    Looks good! (y)
    Are you painting your drip rails?
  8. Recrdholdr
    Recrdholdr National Record Holder
    London Ontario
    I want a 70-73 Maverick
    A fresh set of eyes never hurts.
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks..... I am painting the drip rails, but that doesn't mean there might not be trim on it in the end.....
    Very true.....
  10. igoback70
    igoback70 Member
    IN
    70 Maverick
    Hi Frank, very VERY nice work.
    Have a question though on your choice of motor, with all the work you've put into it, did you ever think about going with a Cleveland instead of the roller Windser ?
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks.....
    As for my choice of motor, and I don't mean to offend anyone else here but you asked...... I don't own a boat, so I have no need for a anchor.....
  12. igoback70
    igoback70 Member
    IN
    70 Maverick
    No offense taken, i am running a roller myself it's a 331 though ---- But if i had made the the tower mod's i would have considerd running a Cleveland. I have a set of 4v heads in the shop and the ports are massive. Also i have driven cars with both types of 351's, not sure if you are basing your judgement of the Cleveland off of a 2v or 4v, but in my experiance the Cleveland walked all over the Windsor. Theres a Pinks All Out episode of a guy running a Cleveland in a fox body, he won and you can tell by watching him on his passes that he was only playing around with most of the cars he went up against. Just thought i'd ask, cant wait to see your's finished, should be a wheel stander.
  13. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Doing a little clean up work around the fenderwell openings the back of the drip rails.....
    Progress pic's here, I didn't include any of it completely gray again.....
  14. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Sand and prime seams like all I have been doing, but I think it's ready for paint finally..... It has a nice coat of primer on it once again, just need a final sanding and the I can squirt it..... Next weekend I am supposed to go to the PRI show in Orlando, but I may have to pass so I can get some paint on this thing before the cooler weather come in..... I will just have to see what the weather is looking like for next weekend, right now it looks pretty good..... No pic's cause it's just gray again.....
  15. ssquier92
    ssquier92 Member
    FL
    1971 grabber 302 v8
    I cant believe I found this thread!! Im Sean the owner of the car who sold it to you. Hope my learning on how to do body work and everything did not give you too much trouble :) I started on it when I was 13 so it is what it is, i would have done it much more like you did had I have the knowledge that I do now...
    I would love to come check it out sometime if you wouldnt mind, seeing the pictures on your first page brought a tear to my eye.. I regretted selling that car the minute you drove it away.. still do.. Maybe ill buy it back from you when your done with it :)
    All the best,
    Sean
