My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I took my drip rail mouldings to work and polished them, I have been wanting to install them badly mostly because it's probably the safest place for them..... I went to the shop this morning and did some cleaning, then I instal the drip rail mouldings..... After that I scuffed the whole insde of the car from firewall to tail light panel with some course scotch brite to get all the loose/semi loose overspray off the floors..... Tomorrow I am going to get the roll bar painted after a little clean-up.....
    Here it is with the drip rail mouldings on.....
    Here's what the floor looks like before and after scuffing.....
    I had it outside to blow all the dust out, so here's a couple pic's out in the sun.....
  2. Demmitt
    Demmitt nutz and boltz
    Sandsprings, Oklahoma,
    1976 2 door, 1969.5 2 DOOR
    as always outstanding(y)
  3. Dave B
    Horrible!!! :rolleyes:
  4. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Great job on the moldings, they really stand out nicely against that blue.
  5. mercgt73
    Frank, the car looks amazing!
    I tried to remove my drip rail moldings... but I stopped before I did any damage. I could not get them to budge. I may leave that to a professional...
  6. John Holden
    John Holden Member
    NJ
    Looks great in the sun! Two questions: What are planning for the floor since you have it scuffed? What did you use and how did you polish the mouldings?
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thank you.....
    Is'nt it.....
    Thanks.....
    They can be tricky to get off sometimes, but it can be really difficult to put back on without denting it up...... I usually use a small block of wood or plastic, I just put it against the inside edge under the drip rail and tap it off with a hammer..... Just start at the front edge and work your way around.....
    Thanks..... The floor will get the typical insulation/sound deadner such as dynamat, fat mat of peel&seal..... We have a big buffer where I work, so first I wet sanded with 600 then 1500, after that I buffed with course then fine compound sticks from eastwood..... If you wet sand like I did you can also polish with Mothers and a Micro fibre towel, it just takes a little elbow grease, but it work good.....
  8. John Holden
    John Holden Member
    NJ
    Oh ok. I thought you were going to paint the floor again since you scuffed it.
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Oh hell no, I just wanted to get the semi loose stuff off it so the sound deadner will stick to the floor properly.....
    This morning I painted the roll bar, actually I should say I painted it twice..... I used paint I had sitting on the shelf and it reacted lets just say not good..... So I got it all off, went and got some new paint and painted it again..... I like to use Rustoleum Harrered finsih Black, which actually looks dark gray with the silver vein that's in it..... I brush it on, makes way less of a mess and with the textured finish it looks really good.....
    Here's what it looks like, you can see the texture it has in the pic's.....
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Didn't get much done at all this weekend, went to the NMRA race Sat..... I did go to the shop today, I opened the hole in the tail light panel when the on/off battery power rod goes through so I could get a grommet in there..... I also sanded the tail light panel in preperation for paint(it is going to be satin black)..... That's it for this weekend, no pic's because there was really no reason too.....
  11. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    I started reading this thread at 8:30 this morning and just now finished. What a hell of a job you have done. :thumbs2: I cant wait to see it when its finished... Good luck and keep up the good work!
  12. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks, glad you like it..... I can't wait till it's finished either, some century maybe.....
  13. John Holden
    John Holden Member
    NJ
    I know the feeling!
  14. cody674
    cody674 Member
    1972 Ford Maverick
    any thing new its been a little while
  15. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I got side tracked for a little while..... My father has been wanting to get a convertible for a while, well we stumbled into one even though he wasn't really ready to buy yet..... It's an 86 Mustang LX 5.0/AOD car, got a good deal on it but it is in need of a few things..... It still had all original suspension components on it, so I am doing shocks-struts-rear control arms-axles-axle bearings-lower ball joints-strut bushings-rear brakes-timing chain-engine reseal-trans service-trans mount-trans crossmember bushings-fuel pump and a few other things.....
    I will get back to my car once this thing is safe and dependable to drive.....:cry:
