My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. Tannersg1
    Tannersg1 Member
    Classified
    AWESOME..............:thumbs2:
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks, yes it does.....
    Thanks.....
    There are a couple that don't quite cover completely..... I will be making an inner reinforcement plate and custom gasket theat will take care of it.....
    Thank you.....
  3. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    What paint did you use for the tailight panel? Car is looking great! Billet Specialties nice choice!
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    It's PPG lacquer, it's some mix that has a fine texture..... It is supposed to be a match for the old factory muscle car blacked out panels.....
    No real progress today, went to a swap meet this morning for a rather short time..... Then went to the shop and picked up/cleaned up a little..... About all I did on the car was put the center caps in the front wheels and take a few measurments for a possible change in direction for the power?????
  5. cody674
    cody674 Member
    1972 Ford Maverick
    as n u found something at the swap meet?
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Nothing found at the swap meet, just something I have been thing about for quite some time.....
  7. cody674
    cody674 Member
    1972 Ford Maverick
    gotch lol its one of those u will see when im done type of thing
  8. slick
    slick Member
    somerset, ky
    73 comet, 72 maverick
    i love the wheels..ive told myself as long as ive had my car that if i ever change from steel wheels and caps, billet specialties are what im goin with...nice work on the car:bowdown:
  9. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    a snail! like the one you had in your mustang ;)
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    exactly!!!!!
    I have had them on my last couple cars, and thanks!!!!!
    Nothing for sure right now.....
    I got out all the rear suspension stuff this morning..... Decided I needed to paint the split mono's before installing them, so I disassembled them - cleaned - sanded and painted them.....
    After preping to paint.....
    After painting them.....
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Well today turned out to be a bit of an adventure, and no really a good one..... First I reassembled my springs and started installing them only to find out that the rear shackel kits I ordered from dearborn classics are not the same ( one is exactly the same as the stock ones and has a nice cadium plating on it, the other has bigger diameter cross pins with different bushings and is not plated )..... Any way I got the driver side sping in place and everthing lined up as it should, but when I got the pass side in place the rear was approx 1" off the outside of the upper mount in the frame rail..... I could get it forced in place but it put an extreme amount of side load on the bushings(remember the front bushings in the with Cal-tracs are solid and do not give)..... What I found is the front spring mounting bolt does not go through the frame straight, but at a slight angle which was causing the spring to br out at the rear(with a stock rubber front spring bushing you probably would hardly notice this, also my original rear shackle bushing were beat up pretty bad on the pass side)..... I needed to do something to straighten the spring, I ended up slotting the hole in the pass side outside mounting tab for the sping eye towards the back of the car approimately .100 thousands which got the spring in line perfectly..... Then I drilled out thick washer to 1/2" and welded it to the outside of the tab to maintain proper alignment.....
    After fixing that and thinking all is well I proceded to test fit the rear..... After getting it bolted in place and putting the axles in, I mocked up the rear tires again..... I found the tire on the driver side to be a bit closer to the front of the fenderwell opening then the pass side was..... After double checking everything I found the the mounting hole for the driver side is approximately 5/16" further forward in the car then the pass side is..... When I say I checked everthing I mean everthing from the front of the car to the rear, It looks like the rear torque boxes are not in the car even..... Just more problems with old cars, nothing has been replaced, wercked or tweaked..... It appears it's just the way the car was built originally and I don't like it even though it probably wouldn't hurt anything in the long run..... I have been mulling over ways to fix this, I'll get it figured out by next week.....
    Here's the springs reassembled.....
    Here's where I slotted the outer spring eye bracket on the pass side and the reinforced it(not the best looking weld on the reinforcement washer due to the factory coating and it being a very awkard plce to get at, I am sure it will hold fine though).....
    Here's one of the rear mocked up.....
  12. williej8749
    williej8749 New Member
    W Knoxville, TN
    '72 Grabber
    Re spark plug looks like it was dropped and not checked after, Classic!!
  13. John Holden
    John Holden Member
    NJ
    What is the purpose/advantage of the split mono leafs? They are not required when using cal-tracs are they?
  14. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    They are not required, but they are designed to enhance the performance of the Cal-tracs.....
  15. John Holden
    John Holden Member
    NJ
    Yes I figured they were designed to work together but I was really interested in why they work better. I already know they're lighter than regular leaf springs.
