My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. CaptainComet
    Wow Frank,
    Bummer on the axle location being messed up. They certainly didn't make cars with robots back then, like they do now.
    My concern with this would be that the car may be prone to launch crooked, especially now that you are tweaking it up with the solid links and traction goodies. I would think it would try to go a bit left by your description.
    It may be able to be band-aided a bit with the front end alignment, but while you are focused on this, it may be your best opportunity to zero it in right.
    This @#$% ain't easy at times, is it?
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Got the driver side front spring position straightened out this morning..... Also moved the rearend locating bolt in the leaf springs back 3/8" to get a little more clearance at the front of the fenderwell opening.....
    Here the driver side spring eye bolt holes slotted to move the position back.....
    Here I welded in the front of the inner bolt hole, ground it smooth and cleaned the hole back up.....
    After double checking spring position I welded a reinforcement on the outer bolt bracket.....
    and here it all is with some fresh chassis paint on all the repaired areas.....
  3. mercgt73
    Lookin good! (y)
  4. Dave B
    Very Nice!!
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    You look good in that.....not my choice of color though
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks.....
    :hmmm:Thanks I think, I really didn't need to see that!!!!!:naughty:
    :rofl2::biglaugh::yahoo::bananaman:rofl:
  7. Dave B
    I was bored....:(
  8. bigdan56
    bigdan56 Member
    Spokane Washington
    04 F150, 2009 suzuki Boulavard m90, 77 maverick
    that bordered on mean and viscous not boring :vomito:
  9. CaptainComet
    I was really enjoying the pictures of the nice welding until some bright green slag popped out of my computer and stabbed me right in the eyeball. Probably should have been viewing this post with my welding helmet on ... owwwwwwww......
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Sunday morning I got the springs bolted in place with the new shackles..... After that I got all the surface rust off the rearend housing..... Then a friend brought by a C4 he was having an issue with so I tore that apart to check it out.....
    The springs in place.....
    Here's the rearend housing after clean up.....
    and here's the scattering of the trans.....
  11. Big
    Big Member
    North Idaho
    x2 to the power of :vomito:
  12. CaptainComet
    Frank,
    How do you get a rear axle looking that good just using a broom?
  13. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    It's a very special broom!!!!!:rofl:
  14. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Went down this morning and finished cleaning up my buddies C4 and put it back together..... After that I figured out I had the tranmission mess going so I might as well go through mine and get it done..... So I disassembled mine and cleaned everything up..... Then I mocked up the new bellhousing on the case and found I had to make a minor clearance on the case then everything was good to go..... I will also need to mill a little off the front of my B&M pan to clear the bellhousing.....
    Here's my buddies C4 back together.....
    Here's my C4 out from under the bench and washed off, along with one of the new bell and brake valvebody.....
    and mine all apart and cleaned up.....
  15. CaptainComet
    You're a brave man ... I don't think I ever want to look at a pile of trans parts like that on my bench .... makes my head hurt. Gimme a nice simple Holley carb to tinker with.
    On the flip side... good thinking to do both at once while you are "in the zone" ... probably makes you sharper at attacking both of them.
