My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Today I got the merge, v-band connection for the crossover pipe and the turbo flange on the pass side header..... Also ground/ported the excess welds out of the header flange openings and where I welded the turbo flange on the inside.....
    Here's the initial cut for the merge area under the turbo flange and one with the second side of the merge tacked on.....
    A couple with the header in place and the crossover connection tacked in place.....
    Here's a couple with everything welded up.....
    A couple before and after porting of the port opening where I cleaned up the BBK welds, and one of the t4 flange after welding and porting.....
    I removed the BBK tag off the header.....
    Here's a couple with the header bolted back on and a couple witht the turbo clanped in place.....
  2. car-nut
    car-nut Glenn
    conn.
    Looking really, really nice.
  3. mercgt73
    That's cool!
    Does it matter that the exhaust from the driver's side has to travel farther than the passenger side? I'm a turbo newb. :yup:
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks.....
    Thank you.....
    No it doesn't hurt anything for them to be different distances, it is not necessary to have equal length headers either..... It is exhaust pressure that turns the wheel in the turbine housing, it's not too critical how it gets there just that it does.....
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Looks good! What are your plans for exhaust from the turbo back, single 3" or so? Maybe split at the rear for duals out the back?
  6. Steven Harris
    Steven Harris Member
    Very nice.
    Educate me a little on the turbo. Which one are you using and why that one. Is there a general formula to follow in selecting one that will work for each specific application?
    How much horsepower do you plan to add with the turbo setup?
    Great work.
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks, single 3" out the back.....
    I am using T76 P-trim with an .81 ar exhaust..... There are formula's for it but I am not great at reading the maps for the turbo's..... I base my selection on engine size and power goals, alot of my selection is based on info I have gotten from others on www.theturboforums.com..... It is a very informative site if you would like to learn more about turbo's.....
    It would not be hard to make alot more then I can use with this set up, I am limited because I only have a roll bar(I can only run 10 flat in the 1/4, or 135 mph whichever comes first)..... I am thinking 550ish rwhp will get me where I need to be on a fairly conservative tune.....
    and thanks.....
  8. blugene
    :thumbs2: You do awsome work! You can work on mine anytime ;)
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks..... Hell, i don't have enough time to work on mine..... :D
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Today I ported the openings of the driver side header flange..... Then I finished the rest of the driver side header..... After that I built the crossover pipe(although I may have to redo the end colse to the driver side header, I had bit of a gap on the bottom side of one of the weld that I had some trouble with..... I am afraid it might give me some trouble later).....
    Here is the driver side header before and after porting the flange openings.....
    Here is the driver side header finished with the v-band flange welded on.....
    Here is the first section on the crossover.....
    Here is the crossover complete, the last pic shows how little can be seen from the front of the car.....
    Here it is with the radiator in place.....
  11. Dave B
    Nice!! :thumbs2:
  12. lastchance
    lastchance Member
    Hingham , Massachusetts
    I just spent the last hour and a half reading aout this build.All i can say is WOW.Amazing work.
  13. cody674
    cody674 Member
    1972 Ford Maverick
    frank i think the pipe go under the car :rofl2:not wrapped around the motor into a turbine jk good work it looks nice man keep it up
  14. sdb416
    sdb416 Member
    TEXAS
    No Maverick now
    Why is this not finished yet!!?? :) I just read the entire thread hoping to see the finished project and youtube video of the road flying out from under the car and come to find there's still more to be finished :cry: How much longer until its done :D I need my fix im addicted!:rofl2:
  15. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks.....
    Thank you.....
    I was going to run it over the, ahh nevermind..... Glad you like it.....
    It all takes time, and I only have so much time to work on it..... It will be done when it's done.....:huh:
