My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. cody674
    cody674 Member
    1972 Ford Maverick
    hell put in out the hood jk man i like ur work so much i went and had pipes put on mine :thumbs2:
  2. Xaan
    Xaan Newbie
    Germany
    70`3,3
    Nice nice! If its finish, sell it to me :bowdown:
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Today I made a little change on the crossover pipe and then started working on the downpipe..... It's almost done, it goes back right to the crossmember..... Tomorrow I will get it through the crossmember and put a v-band flange on it somewhere in the starter area!!!!!
    Here's where I cut the crossover apart and then another with the new piece.....
    Here's whats done on the down pipe so far.....
  4. cody674
    cody674 Member
    1972 Ford Maverick
    that might make changing the starter a pain n a** but it looks good keep up the good work(y)
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    There's plenty of room there..... Just think about a long tube header, 4 1.625" tubes snaking all around the starter before going into the collector..... Mine will just have a single 3" tube, I'll put closer to the frame rail then the starter..... and thanks again.....
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I finished the down pipe this morning..... Also got the wastegate flange welded to the merge..... Next thing is to get the wastegate outlet back into the down pipe.....
    Here is the down pipe.....
    and here is the wastegate flange welded in.....
  7. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Looks great! I can only hope my car turns out as good as yours one day. What size wastegate and down pipe are you running.
  8. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks..... Down pipe is 3" and the wastegate is a Precision 46mm.....
  9. mercgt73
    As always, looks awesome Frank! Are you worried about the down pipe heat affected your water pump pulley and belt?
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks.....
    Not at all..... For one the small cog pulley in the pic's with a water pump drive is what I will be using and it is not that close to the pipe..... The pipe will also be coated in black 2400+ deg ceramic which I have used before, you can damn near toch the pipe right after a pass at the track..... Also the electric fan will be blowing across this area which also helps.....
  11. mercgt73
    Ok, cool! Thanks for the info. :cool:
  12. CaptainComet
    Rainy day and nuthin' to do but weld, eh, Frank.
    Stay safe and dry buddy, weather is picking up.
    I just spent 3 hours moving band equipment to higher ground. Not what I wanted to do with a Sunday ... but, it's all good here.
  13. Steven Harris
    Steven Harris Member
    Okay then. Next.
  14. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Not all day, I was only there for about 3.5 hrs.....
    Umm?
  15. Steven Harris
    Umm?[/QUOTE]
    Just saying. Good deal, still following - looks good.
    Next installment please. Addicted.
