My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Just saying. Good deal, still following - looks good.
    Next installment please. Addicted.[/QUOTE]
    I see, cool and thanks.....
  2. CaptainComet
    You make it through Tropical Storm Debby OK? ... sounds like it was a bit rough where your shop is.
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I have actually been in the same shop unit since September of 89 and have never had a problem yet, the road infront of the shop is low and often floods with a good amount of rain but the shop building is atleast 3 feet higher then the road and we have never had a problem yet..... I actually live just up 49th at 91 ave..... My father was over there yesterday and everything was fine.....
    I assume you made it through OK, looks like where going to get alot of wind today.....
  4. CaptainComet
    Had a couple of issues ... but nothing major ... new-ish Mustang, that we just made the last payment on got two inches of water in the passenger side floor. Plugged cowl drain ... stupid Magnolia tree! and bad design ... rain backed up via A/C. Almost dry again ...
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Today I made the recirculation tube between the wastegate outlet and the down pipe..... After that I need to clean up a little, which turned into the beginnings of a major clean up..... Tomorrow will probably be a major clean up day the way it looks now, mabye I'll be able to get a little bit done after wards.....
    Here's the tube mocked up against the down pipe after fitting.....
    Here's where I cut the hole in the down pipe for the tube.....
    This is after it was welded.....
    and here it is bolted back up.....
  6. blugene
    Amazing.. I can't even clean a hand full of bolts and you've created a masterpiece (y)
  7. super sonic mav
    super sonic mav Member
    Zimmerman,Mn.
    1976 Maverick Stallion
    wow.................:thumbs2::thumbs2::thumbs2:
  8. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks, I don't know about a masterpiece, but it should be a nice ride.....
    Thanks.....
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    All I did oday is clean for about 4.5hrs, atleast the looks good now..... Till I start working again next week anyways.....
    Clean shop.....
  10. Steven Harris
    Steven Harris Member
    Almost too clean.
    You didn't throw the baby out with the bath water did you! (There's no Maverick!)
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    That's the biggest hunk of junk I threw out.....
    Just had it sitting outside while I was cleaning.....
  12. Big
    Big Member
    North Idaho
    :biglaugh: That made me laugh thanks man.
    Shop looks clean, so 4.5 hours well spent.:thumbs2:
  13. CaptainComet
    My garage looked like that once ... about 10 years ago ... right after I painted the floor and moved my stuff in ... :rolleyes:
  14. Bigj47933
    Bigj47933 Member
    Indiana
    1974 Ford Maverick Grabber , 2006 Dodge Charger R/T , 1996 Honda Accord EX
    Dude this thing is sweet!!!! I wish I had half of the skills you did. That looks amazing I can't wait to see it when your all finished.
  15. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks guys.....
    This morning I went to the shop to test fit the new driver side alt bracket I got..... First I had to get a broken water pump bolt out of the block I forgot about.....
    After getting the bolt out I fitted the bracket and it looks like I will need to modify a couple pieces to get it how I want it, but I can make it work..... Next I took a look at the radiator an fittings and what I will have to do to make everything fit properly..... I removed the inlet and outlet off the radiator so I can get the an fittings welded on.....
    Here's the broken bolt after drilling for ez-out, ended up drilling almost to threads and picking the rest out..... I will probably end up putting a helicoil in this hole before assembling the motor.....
    Here's the alternator more or less where it is going to be, I will make final fitting on this when there is a crankshaft in the motor.....
    Here I put the rad back in to try and figure out fittings, but decided I needed the an fittings welded to the radiator before it could be figured out..... and one of the radiator with inlet/outlet fittings cut off.....
