My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    This morning I bent a tube for the return line in the tank and welded it to the an nut..... Then drilled the tanks, fitted/trimmed the tube for proper fit and welded it in the tank..... I don't like the idea of just putting the vent valve grommet in just the sheet metal of the tank so I will make a 1/8" weld in slug to put the grommet in(I will use the lathe at work to do this)..... After that I decided to put my work stands together I bought a couple months ago in preperation of doing more body work.....
    Here's the tube welded to the an nut, then the assembly welded in the tank.....
    Here's the work stands assembled.....
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    As always, your work is top notch! Looks great. :)
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks.....
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I made a piece for the vent grommet the it fits better then just drilling the sheet metal top of the tank..... I also put it on a 1" tall piece of tubing to keep the valve out of the fuel as much as possible..... I welded the tube to the top of the tank..... Then I hung the tank and straps, etch primed them, paint with Chassis paint and textured them.....
    I also went to the junk yard and got a another filler tube for the tank since mine was a little beat up, I also got a really clean pair of rear marker light retaining brackets that someone else was kind enough to remove them for me..... Then I went to work to lightly bead blast a couple pieces to clean them up.....
    Here's the last piece I welded to the top of the tank to hold the vent valve.....
    Here are pic's of it etch primmed, painted and textured.....
  5. native
    native Member
    michigan
    1972 maverick
    Nice looking car! Enjoy!
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Got the gas tank ready and bolted in the car..... Had to rework the gas inlet tube so the emblem on the gas cap lined up properly. got it adjusted/painted and ready to bolt in..... Also got the inner tail light housings, rear side marker inner brackets and bezels painted and ready to bolt in( I did figure out that the NOS rear side marker bezels I bought turned out to be a right rear and left front instead of both rears, so I need to get a left rear).....
    Here's the fuel sender after crimping off the tube and welding it closed.....
    Here's the tank with the sender in, then with the vent valve in the top and the last is the tank bolted in the car.....
    Here's the position of the gas cap with the stock inlet tube, then one of the position with the 74 inlet tube I picked up yesterday.....
    Here's the inlet tube I bought yesterday cut apart to clock it to the correct position, then tacked together for test fit, one of the test fit in the car and then the tube welded together.....
    Here's the inlet tube painted and some other stuff I cleaned up and painted(inner tail light housings, rear marker brackets and bezels(atleast a right rear and left front).....
  7. Mavman72
    Stuff looks good man, devils in the details aint he?
  8. topolino
    topolino Member
    Brazil
    Man... you do art! :thumbs2:
  9. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Amazing work!!!!! I love the detail you have done on every part.
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks.....
    Thanks.....
    and thank you.....
  11. Tannersg1
    Tannersg1 Member
    Classified
    I'm going to un-subscribe from this build because your car makes my car look like.....a Maverick!!!! Lol.... GREAT BUILD:thumbs2:
  12. christurney77
    christurney77 New Member
    mo
    1973 maverick
    Nice looking!!!
  13. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks.....
    Thank you.....
  14. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    This week at work I chased the pins on my 67 Caprice tail light housings to 1/4-20 thread so I would be able to use flanged nuts with sealer to bolt them in place..... I also made some reinforcement plates to put on the inside of the tail light panel..... I strippe all the paint off the outer housings and polished to entire chrome housing.....
    Today I assembled the tail lights with new lenses and seal and bolted them in the rear panel..... I also installed the fuel filler neck I got ready last week and put the right side marker light assembly..... I was going to put the push/pull rod for the battery cut off switch in, but upon searching I could not find the switch itself(aparrently I never bought one, so I went and got one this afternoon so I can get that stuff in tomorrow).....
    Here's the filler neck bolted in with button head stainless hardware.....
    Here's the rear panel with the tail lights, filler neck and gas cap installed.....
    Here's the inside of the rear panel(shows the reinforcement backing plates I made for the tail lights in black).....
    Here's the side marker light assembly inside and out.....
  15. Craig Selvey
    That trunk splatter paint looks real good now that you have some contrasting parts in there.
